Clay bar & carbon fiber ?
Old Mar 17, 2008 | 04:27 PM
Boostedef's Avatar
Just got my car back from the paint shop and got some over spray on the front edge of my carbon fiber hood. Is it safe to claybar it ?? I was planning on using the Meguires kit ???
Old Mar 17, 2008 | 04:32 PM
redlude97's Avatar
Should be okay, but you may marr the clearcoat a bit depending on the what the manufacturer used. A good polish should clean it up if that is the case though
Old Mar 17, 2008 | 04:44 PM
Boostedef's Avatar
sorry its a seibon hood
Old Mar 17, 2008 | 04:48 PM
chilibowl's Avatar
If youre going to clay it, use a fine grade clay bar. A medium grade abrasive clay bar will marr the sh*t out of your clear coat.
Old Mar 17, 2008 | 04:53 PM
Scrooge's Avatar
You can use clay on any hard, non porous surface.
Old Mar 17, 2008 | 04:54 PM
GreenGoblin's Avatar
The goblin resurrection
I would use a good wax first to see how much comes off.
Old Mar 17, 2008 | 04:57 PM
chilibowl's Avatar
How in the fudge would wax remove overspray?
Old Mar 17, 2008 | 05:01 PM
redlude97's Avatar
+1. Even with polishing compound and polisher it takes way to long
Old Mar 17, 2008 | 05:07 PM
Scrooge's Avatar
Clay remove containment faster then compound, wet sanding and solvent without damage the vehicle finish.
Old Mar 24, 2008 | 03:01 PM
Boostedef's Avatar
claybared it and it all came off
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
vQFamily
Sep 30, 2015 01:17 PM
