Ding - Possible For Me To Repair? *PICS*
Old Mar 18, 2008 | 07:31 PM
Birdhouse's Avatar
It's Lonely At The Bottom
Wind + Shopping cart + lonely g35 in parking lot =
It's small, but a ding that is bugging me. What tool or method can I use to repair this myself? Anybody with experience come on in!
Old Mar 18, 2008 | 07:33 PM
speedracerg35's Avatar
absolutely...go to dent wizard online and look for a master-tech in your area.
Old Mar 18, 2008 | 07:37 PM
Birdhouse's Avatar
Thanks for the tip, but what is this going to cost me for somebody to repair this for me? I wanted to do this myself to avoid going through my insurance.
Old Mar 18, 2008 | 07:38 PM
redlude97's Avatar
~$100 from a PDR place. You cannot fix that yourself
Old Mar 19, 2008 | 08:23 AM
GR8TG35's Avatar
Redlude is right, don't attempt to repair that yourself...you will end up with little dimples protruding out of the fender.
I had my fender lip creased, and Dent Wizard removed it 99% Charged me $95
Best investment I made beside my rim repair.
Old Mar 19, 2008 | 09:03 AM
GreenGoblin's Avatar
The goblin resurrection
ya +1 on Dent wizard I had them take on out of my door near the handle it bothered me so much
Old Mar 19, 2008 | 05:17 PM
Birdhouse's Avatar
Thanks for the help guys. $95, darn, my insurance is a $100 deductible (comp). Either way I am going to pay up.
Old Mar 19, 2008 | 05:21 PM
yes, pay a pro to do it because you will only make it worse (not commenting on your skill as a handyman, rather, commenting from my own history trying to fix a dent this way). a master tech will make this thing disappear like it was never there.
Old Mar 21, 2008 | 03:51 PM
stevek247's Avatar
I also just got a door ding on my brand new ride... Bugging the **** out of me... I googled some stuff on door dings and came across some vid clips about self fixing... but hesitant about trying it... It involves, DRY ICE or one of those CAN AIR... apply it to your ding/dent and suppose to pop right out...
Take a look...
http://www.metacafe.com/watch/501379/remove_car_dent_with_airduster/
http://www.metacafe.com/watch/820799/secret_paintless_dent_removal_technique_easy_and_cheap/
If you try this...or tried this..and it works... LET ME KNOW!!!!! i'm affraid of it messing up my paint or something...don't want some little off paint color on my car...
Old Mar 21, 2008 | 04:02 PM
stevek247's Avatar
found this stuff too.. my friend said he tried this..and it seemed to work well...
http://www.harborfreight.com/cpi/cta...emnumber=94887
http://www.dingking.tv/?source=gg&s_kwcid=door%20ding%20repair|746654599& gclid=COq4h_T-npICFRBaiAod3xpwXQ
Old Mar 21, 2008 | 04:32 PM
stevek247's Avatar
WELLS!!... i got the guts to try to compressed air thing... but it did not work on my lil ding... Ding still there...
Old Mar 25, 2008 | 09:18 PM
geronimomoe's Avatar
Take a look...
http://www.metacafe.com/watch/501379...ith_airduster/
http://www.metacafe.com/watch/820799...asy_and_cheap/
Last night I found the links you listed. Wondering if the technique is going to work.....
For those who don't understand, basically the hair dryer heats the entire area of sheet metal. The compressed air cannister or dry ice cools the exterior surface of the sheet metal a lot faster than the inner surface. Hence, the molecules of metal at the surface shrinks at a faster rate than the inner part of the sheet metal, resulting in metal popping out.
Of course, the concern is will the extreme cold damage the paint.....
Old Mar 25, 2008 | 09:58 PM
none of that crap works. go and spend the hundred or so bucks on a pdr guy to get it fixed right. you may do more damage trying this gimmicky garbage. fyi, if you wanted a bodyshop to repair and paint, you would be looking at $350-$500.
Old Mar 25, 2008 | 10:41 PM
kenchan's Avatar
for that, i would pull out my regular rod type PDR tool to massage it out.
glue pullers will work in that area, but it'd be faster to do with the regular
tools.
Old Mar 25, 2008 | 10:46 PM
i've seen a demonstration done with glue puller that leave two ding where the puller sits. in the end, instead of one bad ding, you have three mild ones.
