cleaning OEM rims
Old May 20, 2008 | 06:08 PM
lekker_droom's Avatar
cleaning OEM rims
what do you guys use to clean your OEM rims?
More important, what chemical should I look for to AVOID using on the rims.
Old May 20, 2008 | 06:12 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
P21s gel FTW....
But if you seal the wheels (wheel wax etc) they clean very easily.
SteveBlake's Avatar
I used to use soap and water, but i dont have my stockers anymore
Old May 20, 2008 | 06:13 PM
Sbeck's Avatar
Originally Posted by SteveBlake
Just use soap and water and you'll be fine
^^ +1
Old May 20, 2008 | 06:14 PM
Calvin's Avatar
Overglorified Altima
soap + water
Old May 20, 2008 | 06:37 PM
sweet. easy enough.
Old May 20, 2008 | 09:13 PM
Beebo's Avatar
Originally Posted by aHero4Eternity
soap + water
^+1
Old May 20, 2008 | 09:17 PM
blueboxer's Avatar
The P21S Wheel Cleaner is a great product and always kept my wheels clean and kept the clearcoat in perfect shape. However, it is probably not cost effective for stock wheels, but I highly recommend them for Volks and the like. For the stockers, just buy a good wheel wax/sealant so cleaning them is easier. It is the same as your paint, the wax and sealant will help keep the brake dust and road grime from sticking to them.
P21S Wheel Cleaner Gel
Wheel Sealant
Old May 20, 2008 | 11:13 PM
Scrooge's Avatar
10:1 of APC to clean my chrome rims FS APC to clean tires.
Old May 21, 2008 | 02:24 PM
Detailed Image's Avatar
Wheel Sealant
Well put. Personally, I just use automotive shampoo and water as others have mentioned, but I always make sure to have a couple of coats of Poorboy's Wheel Sealant which makes cleaning wheels significantly easier. P21S Wheel Gel is a great product for high polished aftermarket wheels.
George
Old May 22, 2008 | 10:33 AM
DyslexicG35's Avatar
Not to highjack but my wheels are in pretty rough shape. I don't know what the previous owner did to them. Its like theres brake dust embedded in the finish and I've tried soap and water and even some wheel cleaner but its not touching it.. Any suggestions?
Old May 23, 2008 | 03:38 AM
blueboxer's Avatar
What type of wheels? The chemicals may of eaten through your clearcoat already. (
Old May 23, 2008 | 10:03 AM
Stock 7 Spoke 18" wheels.. Used eagle aluminum wheel cleaner on one of the wheels and it looks pretty rough, stuck to soap and water for the rest because it looked like it did bad things : /
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Gip
Aug 24, 2015 05:31 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
