Porter cable 7424 nightmare...
Old Jun 9, 2008 | 04:32 AM
deuceduzit's Avatar
.....I just did my first DIY detailing today after receiving a 7424 as a gift..... I now have massive haze all over the place...Does anyone know how to remove this stuff???? I used NXT which caused the haze....used the black pad on 5-6....I tried using Meguirs step #2 polish with no results....Can someone please help me...Don't want to live with my beautiful G looking like she just got out from a oil fighting competition....Thanks in advance dudes..
.....I was out there in my garage for a total of 7 hours today trying to get the haze off....PPPPPLLLLLEEEEEAAAASSSEEE help me....
Old Jun 9, 2008 | 07:20 AM
GR8TG35's Avatar
I don't see how the NXT could have caused the clouding. Maybe you used the wrong pad? Some of the pads are more aggressive and are meant for polishing, not waxing. Also, isn't it normal to run the PC at or around 4-5 setting?
Sounds to me like its micro marring, which is normal in a two or three step process to restore the finish. You may need a more aggressive polish, and then a finishing polish then wax.
I'm sure the porter cable/detailers will chime in and make sense of it......
Good luck
Old Jun 9, 2008 | 07:33 AM
35bills's Avatar
Try a 50/50 mix of water-iso alcohol on an inconspicuous area that is hazed. Spray this on the area to see if the haze will be removed, then you will know if its the NXT or not.
Do you have any pics of the problem?
Old Jun 9, 2008 | 07:40 AM
loudog2's Avatar
your supposed to use the blue pad at speed of 3.
Old Jun 9, 2008 | 02:12 PM
deuceduzit's Avatar
Is that to put on? Or remove? I use the applicator pad to put on & the light green/turquoise pad on speed 5-6 to remove.
Old Jun 9, 2008 | 02:54 PM
Detailed Image's Avatar
Did you use NXT paste wax? or liquid wax? I'd never recommend using a paste wax with the PC, too much wasted product and you have the potential to swirl the paint. Also, you should never remove with the PC, remove with a quality microfiber towel by hand. If it's excess product, isopropyl alcohol and water should get the excess product off, but you'll also strip off the protection. This would mean you need to reapply the wax. If it's actual hazing from cutting into your clear coat, then you'll need an abrasive polish to remove it.
Hope this helps.
George
Old Jun 9, 2008 | 03:15 PM
deuceduzit's Avatar
So......You think Dawn will fix everything & then I can start all over again?
Old Jun 9, 2008 | 03:20 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
No...
Like others have said, use 50/50 Isopropyl alcohol & water.
Try a test area 1st
Old Jun 9, 2008 | 07:23 PM
archie's Avatar
someone should read meguiars recommendations for pads and speed with their products. you should also read how to use each product. your best bet is to get the pc training video (http://www.autodetailingsolutions.co...ailing_dvd.htm) as it is a informative video.
here is the link to meguiars product and speed recommendations
http://www.meguiarsonline.com/forums...ead.php?t=2524
(please note that g100 and pc are the same machine)
Old Jun 9, 2008 | 08:28 PM
Scrooge's Avatar
Why buy the video. Theres free videos in the Video and media section of this the detailing forum.
Old Jun 9, 2008 | 09:26 PM
If it's excess product, it can help, might not fix everything though. Depends on how thick it was applied. Remember in the future, thinner is better. Removing a product when properly applied usually requires very little effort.
Good luck, keep us posted on what you do and what ends up working for you.
George
Old Jun 26, 2008 | 08:15 AM
deuceduzit's Avatar
OK.....So I'm going to try this all again this weekend....Been so busy with work....I just purchased the Zaino Ultimate kit.....any suggestions on how to use this thing???....I'm thinking about getting the Meguiars #9 swirl remover to remove my light spiderweb swirls....I currently have the porter cable 7424 with LC pads....Which one should I use for the swirl removal???....Thanks for all the response btw
THANK YOU all again for helping me try to reach my goal for a swirl-free, shiny car! THANKS
Old Jun 29, 2008 | 05:28 PM
munkyv22's Avatar
Not sure if you fixed your hazing, but.
Use a polish that is about a 5 on the abrasive scale with an orange pad. Speed 3 to spread, speed 5 to work, remove residue by hand with a MF towel.
Next use a polish that is a 2/3 with the white pad. Same speeds and removal.
Next clean everything off with 50/50 alch and water.
Now apply a glaze by hand and remove by hand.
Finally apply a good wax by hand and remove by hand.
If your car still has issues after that, you are probably just doing something wrong. PM me if you have any questions.
Old Jun 29, 2008 | 09:14 PM
badtziscool's Avatar
Take a picture of it and post it up so we can see exactly what it looks like. Better for troubleshooting.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
