2 questions
Old Jun 27, 2008 | 06:02 PM
c4m's Avatar
c4m
Exclamation helppp
1. What is the best method for removing this strip down the side of my car? :
2. Any recommendations on an adhesive to fix a loose brushguard/mudflap whatever they are called?
SEE BOTTOM POST
Old Jun 27, 2008 | 06:12 PM
omgitselaine's Avatar
Not so sure about an answer to #2 but concerning #1 just be 100% sure theres no holes behind those moldings and when you're ready a simple fishing line , goo gone and a nice hot day should do the trick
Old Jun 27, 2008 | 06:13 PM
snavematt's Avatar
just a sedan
#2 just use 3M (and 3M only) Body molding tape
Old Jun 27, 2008 | 09:57 PM
LMG_35C's Avatar
3M makes a great automotive adhesive remover that's better than Goo Gone. Walmart carried it and removing lettering was a breeze - no discolor and no pressure.
Old Jun 28, 2008 | 07:58 PM
c4m's Avatar
c4m
k so I just got done removing the side strips and there is still an outline of where they were.. ive scrubbed the **** out of it with goo gone with no luck.. I think its partly dirt but im not sure.. what should I do now?
Old Jun 28, 2008 | 09:43 PM
snavematt's Avatar
just a sedan
wash, clay, polish, wax. if you can buff it that may work as well
Old Jun 30, 2008 | 02:26 PM
c4m's Avatar
c4m
okay so now i have a delema..
None of the buffing and polishing was doing any good, so I took it to a body shop, and the guy tells me that the doors and front of the car have been repainted (the part of the side trim that was on the rear panel instead of the door came off fine and left no marks), which means it was probably wrecked (stealership/carfax didnt show any accidents).. So now I'm either gonna have to reattatch the sides or get the doors painted..
Heres a pic:
sooo. do you guys think there is any way to get the dealership to repaint/touch it up seeing as how the car has obviously been repainted and they did not mention anything about it? or am I just **** out of luck?
Old Jul 8, 2008 | 11:31 AM
racefan318's Avatar
On brand new cars, dealerships are required to disclose any transport/lot damage greater than $500.
Look at the inside edge of the door where the "skin" is wrapped around the door shell. Now go look at the other door. Do they look the same? If so, there was metal/bondo work done on the panel. If the painted side doesn't look OEM, then it probably had a door skin put on it. Neither is bad, don't hate the car for it.. If you didnt notice until now, then the body shop did a good job.
As far as getting the dealership to pay to repaint it... you can try it, but if it was the Used Car Dept, you will have a long uphill road...
Old Jul 11, 2008 | 09:33 PM
c4m's Avatar
c4m
yea I checked the carfax it was wrecked... twice.. but when we bought the car the dealership gave us a "autocheck report" or something that said it had never been wrecked. It was repainted from the doors to the front. We are trying to get the stealership to repaint the doors.. its the least they can IMO, because I definately woujldnt have payed as much as I did for that car if I had known it was wrecked twice
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
