Emergency brake aluminum pedal question ...
What does the back of yours look like and how did you glue it on? The back of mine is just a flat square. When take off the stock pedal, there isn't a square on the other side. So how does it glue on?
Re: Emergency brake aluminum pedal question ...
i wouldn't try to glue it....if you drill out the center of the pedal it will line up with the hole in the brake arm, then you can just put a flat head screw/nut through it.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
i kept the oem rubber pad on, used automotive grade silicone, and slapped the aftermarket one on that. the new one will not come off without taking the oem one off. so it's safe to say that it's pretty secure.
I used a standard screw and nut to install the e-brake pedal.
Borla exhaust, Nismo sway bar, Z duct, JWT p/c, Kinetix cats [img]/w3timages/icons/laugh.gif[/img]
I believe that's an FX dash.
kinetek
Aug 3, 2015 04:25 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
