Bad odor smell from the A/C vents??
if you turn your car off with the a/c running, condensation will build up and give you those bad smells the next time you get in. just turn off the a/c a couple mins before you get home and that should work.
Originally Posted by Polishthrust
Change the cabin air filter. I had the same problem, it went away after i changed mine.
and if you want a quick refresh...
- turn the A/C on MAX and the fan on HIGH
- from the driver's seat, spray a couple of shots of Oust Air Sanitizer into the passenger floorboard area...
- enjoy
It doesnt last forever, but it gives a nice overall clean smell to the interior... works great for delivering a repair job back to the customer!
