350Z engine cover
Old Apr 27, 2004 | 06:56 PM
esemes's Avatar
350Z engine cover
anyone know if the 350Z engine cover (aka heat hat) will bolt onto our G's??? i have a neat idea, but it is using the less covering Z version.....
anyone have any pix of one installed on the G also??
much thanks
scott
Old Apr 28, 2004 | 01:23 AM
Gsedan35's Avatar
Re: 350Z engine cover
I have one on my car and here's a member that has pics of his, see the pics here https://g35driver.com/rides/detailride.php?vehId=2670
Of course both of us have Crawford pleneum's.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Apr 28, 2004 | 06:28 AM
z_with_back_seat's Avatar
Thanks for the plug !! The link above is to my coupe with a Crawford, 350Z Tube and Stillen Box.
Check out my350z.com if you are looking for a used one that is where I found the one I modified. If you have not added a plenum (Crawford, Kinetix) it should be a direct bolt on. Just remember to keep your 4 rubber grommets and 4 metal inserts off you existing stock cover. Most of the 350Z guys are keeping them to use on their CF covers.
Good luck and share some pix when you are done!
G35C - 6MT, DG/G, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford v5, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Tint & more to go
Old Apr 28, 2004 | 11:14 AM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
The "Z" cover will fit unless it's with the Crawford Plenum, then you would just have to cut a little material out to match up w/ the Crawfords new angular front section...........
You could always just cut your "G" engine cover & mount it in front of the Plenum like a "Z" cover...
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
joedaddy1
Jul 28, 2015 02:58 PM
