Painting Grill Black
Old Jul 24, 2008 | 02:26 PM
Convert35's Avatar
I want to take the grill off my OB Coupe and paint it black, but I can't find a solid step-by-step on how to actually do it or what brand of paint is good to buy. I know I'll get people telling me to use search but trust me I've tried many times.
Can someone please help me out.
Old Jul 24, 2008 | 02:38 PM
Yv12345vY's Avatar
You should search, this topic has been covered.
https://g35driver.com/forums/body-interior-exterior-lighting-diy/189792-diy-blacked-out-grille-w-pics.html
Old Jul 24, 2008 | 02:39 PM
O HELLA OEM's Avatar
its really easy!
Old Jul 24, 2008 | 02:42 PM
JAYY-G35's Avatar
dupli color sandable primer
dupli color (what ever color you want)
dupli color clear coat
sandpaper. (320, 400, 600, 800)
very easy mod..
320 sandpaper will strip all that fake chrome off. i actually wet sanded mines and it came off with a breeze.
then work your way up 400, 600 & 800..
wash off w/ soap water. then let dry.
move on to the sandable primer (3-4 coats)
then your dupli color paint (3-4 coats)
final step is the dupli color clear coat ( i only use 2 coats, some guys use more for a super glossy look)
Old Jul 24, 2008 | 03:47 PM
Convert35's Avatar
Thanks BKZ, but what about removing the grill itself? I popped off all of the plastic pins, is it supposed to just slide out or am I missing something?
Old Jul 24, 2008 | 03:52 PM
caltender's Avatar
A quick SEARCH and I found this
https://g35driver.com/forums/showthr...Y+remove+grill
That is a Sedan. This link explains it as being alot simpler
Another
https://g35driver.com/forums/showthr...+grill+removal
Old Jul 24, 2008 | 04:25 PM
JAYY-G35's Avatar
you pretty much have to put your hand behind the grill theres 1 plug on each side, pretty much have to give it a little tug.
Old Jul 24, 2008 | 05:01 PM
Convert35's Avatar
Idk maybe I just fail at life but I'm pretty sure I see the 5 or 6 clips down at the bottom of the grill holding it to the bumper but I can't get them to budge.
Old Jul 24, 2008 | 05:42 PM
G35Ian's Avatar
Do it dude it is super easy and you only need to spend like $20
Old Jul 24, 2008 | 05:44 PM
G35Ian's Avatar
just push the center of the clip down a bit and slide the clip out...It looks harder than it is...just take your time
Old Jul 24, 2008 | 07:47 PM
JAYY-G35's Avatar
here's the best DIY
http://www.five-fifths.com/GrillDIY.pdf
Old Jul 24, 2008 | 09:02 PM
Convert35's Avatar
Hey I got the grill off and I have all the materials, I'll post pics when I'm done.
Old Jul 24, 2008 | 11:29 PM
SpecC's Avatar
yes it's easy.... but do you really want to have to repaint now and then? it chips like crazy
Old Jul 25, 2008 | 01:40 AM
JAYY-G35's Avatar
Ok Cool Bro, Make Sure You Take Your Time With The Prep Work.
jsimonk
Dec 22, 2023 03:49 PM
Genthusiast35
Jan 19, 2016 02:19 AM
realtalk21
Jul 20, 2015 09:07 AM
