Detailed: 2008 Black G35 Sedan
Old Nov 11, 2008 | 02:03 PM
Darkstar752's Avatar
Where did you get all of your products from? I googled most of them and found nothing.
I just started detailing cars, I'm probably gonna start doing it as a side job. I'm a college student and looking for ways to make money over the summer and I want the cars I do to come out like this. So far I've only used basic products that only get out some of the swirls and marks, but no where near what you do.
Can you reccomend me some good budget products? I also still need to buy a buffer, can you reccomend a good but cheap one?
Old Nov 11, 2008 | 02:23 PM
Concours Finish's Avatar
Detailedimage.com carries most of the stuff I use. Zaino is obviously bought directly from them. Prima can be found on detailersparadise.com
I would recommend using a Porter Cable 7424 when you are starting out. Eventually I would get a Makita 9227c as it allows more correcting ability and in my opinion finishes off better than a orbital buffer. But be careful and practice before using it on clients cars as it can burn the paint if not used properly. Good luck and post up some pics.
Old Nov 12, 2008 | 01:05 AM
KapVu's Avatar
Why did you use the Prima Finisher?
Could I use the P0106FF with the Orange pad? What would I then use with the white pad as the Finisher? I would like to stick with something Menzerna.
I was then going to use a Zanio sealant and then the NXT 2.0 wax.
I'm planning to use the PC7424. Would you change any of this? I have an 03 black coupe.
Old Nov 12, 2008 | 02:41 AM
It depends on your cars condition. I would start with P0106FF on a white pad to see if that remove all the defects. Infiniti paint is rather soft so it might all come out. Remember to use speed 5-6 and slow passes of 1 inch per second. If not, then go with the Orange Pad. If that doesn't work, you will need Super Intensive Polish P083 with an Orange Pad.
I don't think NXT 2.0 over zaino would improve the look or durability. I would just layer on more zaino z5 or or zaino z2 with zfx accelerator. Hope this helps. Post some pics when you're done.
Old Nov 12, 2008 | 12:27 PM
KapVu's Avatar
Thanks for the tips. I haven't bought anything first. I'm doing a lot of research and finding out the best products + pads combos. Thanks again for the tips. I will look into Zaino.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
