Detailed: 2008 Black G35 Sedan
Detailed a brand new 2008 G35 for fellow forum member. Condition was good for a new car. Still needed a multi-stage polish to remove the defects.
Wash
Prima Mystique Foam Cannon
Prima Mystique 2 bucket wash /w 3 lambswool mitts
CR Spotless final rinse - air dry
Wheels/Wells/Tires
APC+ on wells and tires
P21S Gel Cleaner on wheels
Clay
Adam's Purple Clay
Correction
Menzerna P0106FF - White Pad - 900-1200-900 rpm
Prima Finish - Black Pad - 900 rpm
Sealant
Zaino Z5pro /w ZFX - 3 layers
LSP
P21S 100% Carnauba
Swirls & Holograms on Rear Bumper
More Swirls & Holograms
The key to making any tire shine look good and last longer is clean tires
After claying trunk lid
Trunk 50/50
Rear Quarter Panel 50/50
Driver side doors 50/50
More 50/50s
Closer up
Hood Before - Swirls and lots of holograms
Another shot of hood
Taped up and ready for 50/50 of hood
Hood 50/50
Closer up 50/50 of Hood
Afters
Wash
Wheels/Wells/Tires
Clay
Adam's Purple Clay
Correction
Sealant
LSP
P21S 100% Carnauba
Trunk 50/50
More 50/50s
Closer up
Hood 50/50
Afters
OMFG that is amazing. How much would it cost to get it detailed like that?
And what is that white stuff you put all over the car?
Also, didn't know those white marks were called holograms. I have several in the rear bumper.
Originally Posted by Scrooge
Ah why let a mf fall on the floor
That would be car soap from my foam cannon
Holograms are also called buffer trails. Holograms are created when using a High-Speed Rotary buffer and not following it up with a finer polishing step. The car was only 2 months old which means that the detailer at the dealership went over the car with a rotary and didn't bother to finish the job.
Originally Posted by FlSHRFun
Great work, man. How long did that take you? When'd you start and finish?
Originally Posted by lmulion03
I was used to my car with holograms and was expecting to see them once he got done, but none appeared! It definitely is a head turner. Great job dude.
