Changing pad vs polish for paint correction
Old Aug 4, 2008 | 12:37 AM
TheIvoryG's Avatar
What do you do?
When polishing, and you realize you need something stronger, do you tend to up the polish or the pad or both?
For example. This weekend I was using white lake pad and PO106ff(mild polish) and knew I was going to need more bite for a few sections. Would you go to orange pad with light polish, SIP(medium polish) and stick with the white pad, or change both then come back to finish with light polish and white pad?
Would love to get some feedback from others...
Old Aug 4, 2008 | 03:22 AM
Concours Finish's Avatar
It's all based on preference. I usually go more aggressive polish on same pad. I still find po106ff goes best with white lc pad and SIP goes with orange.
Old Aug 4, 2008 | 04:20 AM
SpecC's Avatar
It's just a judgement call. Some pads aren't meant to be used on certain polishes because of the cut though.
For example, you wouldn't use a finishing polish (106FF, PO85RD) with an orange or yellow pad because they're too heavy. Likewise, you wouldn't use a light pad with strong polish because it wouldn't cut.
Old Aug 4, 2008 | 06:25 AM
dreamcatchr's Avatar
I'm far from an expert, but my personal preference is to use only one product on a pad until i get a chance to clean them (and when i made my initial purchase, i ordered a ton of pads so i'm definitely not short of that)... so when i step it up to a stronger polish/compound, i would also change to a stronger pad to match... and in your example, i would definitely go to an orange pad for the SIP and then step it back down to PO106ff on a white pad...
Old Aug 4, 2008 | 10:11 AM
Detailed Image's Avatar
I always recommend matching the aggressiveness of the polish with the aggressiveness of the pad. Reason being, if you use too aggressive of a pad with a lighter polish (ie. PO106FF with an orange light cutting pad), you may be filling in light holograms or hazing and not realizing it. If you're seeing improvement with the current polish / pad combo, then you can jump to a more aggressive pad for faster results. If the results are minimal with a current polish / pad combo, I'll jump to the next level of polish / pad combo.
I stick to these rules personally:
Also important to note, change your pad out for a new one after every few panels or at least clean it out. The more caked up the pad becomes, the harder it is to finish down as clean as the first panel when the pad is fresh. Excess product can lead to difficult product removal, not being able to break down the polish completely, and excessive dusting. I usually use about 4 pads per coat of polish, swapping them out roughly every 3 panels or so. On some paint I use even more.
Hope this helps.
George
Old Aug 4, 2008 | 10:21 AM
TheIvoryG's Avatar
Thanks everybody...especially since a few of the heavy hitter detailers chimed in.
Like concours said...I typically just think that PO106ff just works better with white while SIP works better with orange. Just wanted to see if I was missing out on some other tricks.
George your rules are perfect...thanks as always!
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:23 PM
bickfordbft
Jul 20, 2015 07:57 PM
