Menzerna has done it again with another outstanding ceramic clear coat polish! The Menzerna PO203S polish is designed to remove swirls, fine scratches, oxidation and more from the new ceramic clear coats and all traditional clear coats. The remarkably smooth cutting particles help leave the paint extremely smooth and vibrant looking. It is a light to medium cutting polish that can help restore the clear coat so it is smooth and vibrant looking again. Menzerna PO203S can be used on some lighter colors as a finishing polish with outstanding cutting power. For those who want to do just one coat on lighter colors and get the maximum results this may be the product for you. For darker colors you may want to follow up with a lighter polish like the ultra fine polish Menzerna PO85RD or the PO106FF. These polishes will ensure the paint looks totally clear and crisp. I would most commonly use the Menzerna PO203S with a white polishing pad, but there are certainly other options. It could be used with an orange light cutting pad if you're following up with another lighter polish/pad combo or with a black finishing pad if you want to use the polish as your finishing polish.
In terms of aggressiveness, it falls between Super Intensive Polish PO83 and PO106FF / PO106FA.
If you have any other questions about this product or anything related to detailing please let me know.
George @ Detailed Image
Quote:
You got it. Still finishes down very fine but has more bite than 106. Kind of a best of both worlds type polish. On colors like flat black and other dark colors, I'd recommend following up with something like PO85RD and a black or blue pad to bring out the maximum depth and gloss in the paint.Originally Posted by GTScott
Would it be reasonable to say this is like 106 with a kick? Sounds interesting.
If you end up giving it a shot, keep us posted on how things turn out for you.
Cheers,
George
Power Finish (PO203S) - (M) this is a a one-step scratch remover polish that will remove 2500 grit, cut 3.0- gloss 3.0, Slightly more abrasive then PO 106 but produces a burnished finish (for black or dark coloured paint surfaces use as part of a duel level foam pad / polish system PO 85 RD 3.01 Super Intensive Polish) 1500 RPM - primed LC Orange / Green (mid range, high density foam (60 PPI) medium abrasive cutting action) or a White primed (softer less dense foam (70 PPI) with a light abrasive cutting action)
See article Polishing - Menzerna Polishes - http://detailingwiki.com/index.php5?...zerna_Polishes
Am I the only one that feels like Menzerna is creating a lot of polishes all within a very small distinction range? PO203S and SIP seem very close, while PO85RD and PO106FF seem similar too. Literally 4 levels of polish between 106FF and SIP???
If they would only create a heavy compound that is nice. PG is horrible IMO. I much prefer 3M extra cut compound.
Quote:
I myself like Hi temp extreme cut.Originally Posted by gmblack3
Quote:
You should just detail cars that are in better shape, then you would not need a more abrasive compound! Originally Posted by gmblack3
Come on man...post up some pics of that Benz.I am still loving the Presta line you introduced me to.
