Small Rusty Spots
Old Nov 20, 2008 | 12:17 PM
jfats100's Avatar
Small Rusty Spots
I have some small rust spots on my roof and I have read the DIY on how to touch up small chips in the paint. Should I touch it up like a normal chip in the paint, or are there extra steps I need to take to remove the rust and possibly add primer... ? idk. Any help is appreciated.
Old Nov 22, 2008 | 01:48 PM
Picus's Avatar
Staff ALUMNI
If you use a rust converter (which you should), then there is no need to add primer. I am not sure where you can get rust converter locally; but most automotive supply stores have it. POR-15 is the most common. All you need is a little jar of it, it'll be a viscous liquid (should say paint safe), just apply to the chip and let sit for a few minutes, repeat as needed until all rust is grey/white (it turns rust into primer). When that's done touch up as normal.
Old Nov 22, 2008 | 04:14 PM
jfats100's Avatar
Excellent! Thank you.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Kelvin Style006
May 23, 2016 03:47 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
