Klasse Apply Question
Old Jun 29, 2004 | 01:09 PM
dsully444's Avatar
I know there are threads about the application of Krasses, but they are spread all over and I have done a search with out much luck.
I just bougt the Klasse AIO to replace my Pinnacle Cleansing lotion followed by the Souveran. What are the techniques apply the AIO. I have the detail spray and microfiber pad and applied it and it appears to have left swirl marks. What kind of pressure should I apply? As far as following up with the Klasse SG I thought you apply to whole car and follow up with detail spray on a microfiber detailing towel. Do you have to wait before applying the SG over the AIO? I know some posts say not to apply the SG over AIO and then follow with the Souveran bc it hazes, any experiences with this? Or does the SG provide a better shine and durability when sandwhiched? Does the AIO have to cure before applying he Souveran? I have a few paint chips, will the SG help protect my car better than just the AIO from further chips, as it states it provides an elastic non-chip surface. Any other tips with these products for application would be appreciated.
Old Jun 30, 2004 | 02:37 AM
mizzoutiger's Avatar
Re: Klasse Apply Question
this should help, http://www.properautocare.com/klaskit.html
Old Jun 30, 2004 | 10:21 AM
CookG35's Avatar
I now use a Porter Cable to apply the Klasse AIO, but before that I used a mf pad. It goes on very easy and comes off with little effort using mf towel. Do one panel at a time. You need to work it in a little (medium pressure), especially if you have small scratches /swirls to hide. As long as your car is clean and the applicator is clean you will not get additional swirl marks...it will help to clay the car before this process as well. You don't need detail spray for this step.
On the SG do one panel at a time, (new mf pad) and this goes on lightly. Some recommend 24 hrs. between the AIO but I don't. Let dry for just a few minutes, then remove with clean mf cloth. You may have to experiment with drying times for ease of removal. Now is where the detail spray comes in, IF it is difficult to remove the SG then apply a little spray and buff with mf cloth. I have never had to use the spray and likely you won't either. Don't cake on the SG, use very little and you can layer the SG as desired. I do believe the SG adds a layer of protection and "hardness" if you will. After that I follow with Pinnacle Souveran wax (topper coat)...but you can use anything or nothing. I feel the carnuba adds a little depth.
Old Jun 30, 2004 | 01:16 PM
waijai's Avatar
i.love.gold
I always apply with a back/forth motion. From front of car to back of car. I never use circular motions when applying or removing.
b2autodesigns
Accessories-Vendor
84
Jun 20, 2017 04:38 AM
Detailed Image
Aug 7, 2015 02:10 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
