Head light tint removal glue residue problem!
Old May 9, 2009 | 11:57 PM
Robs_04G35's Avatar
Glue on lights
That's really weird. I had them on my car too and removed them quite easily with just a blow dryer. Are you sure you bought the re-usable kind? There is a huge difference because there are some that are "re-usable and come off easy and those that are not which are meant for permanent use. I would try going to a dealership to see if they have any industrial glue residue remover. I work at a Chevy store and the stuff we has works wonders. Hope this helps.
Old May 12, 2009 | 09:27 AM
jkchang10's Avatar
yeah i definitely bought the reusable/removable tints...
Old May 12, 2009 | 12:09 PM
Darkstar752's Avatar
3M adhesive remover. Now. Your headlights are probably damaged from everything else you have been trying.
Old May 12, 2009 | 07:54 PM
4DGS's Avatar
What's wrong with wet sanding? I wet sanded mine and they look brand new?
Old May 13, 2009 | 09:22 AM
jkchang10's Avatar
if you wetsand you can remove the protective film off your head lights that keeps it from yellowing due to UV rays....
Old May 13, 2009 | 11:12 AM
Yep.
Just like the paint on your car, there is a clearcoat on the lights that contains UV inhibitors that protect it from fading/yellowing. Wetsanding DEFINITELY removes this and permanently damages the headlight. Sure it will look good for a while, but the yellowing will come back. The only way to prevent permanently it is to have them re-shot with clear. However, a light polish to remove the oxidaton and a long lasting wax will help delay the yellow from coming back significantly.
If your headlights haze up, just use a light polish (PlastX) and then a good, long lasting wax (Collinite)
Old May 13, 2009 | 01:47 PM
4DGS's Avatar
I've done it on all my cars?
My last car was wetsanded and I had it for 6 months (hot summer months) and they still looked new?
Same with this car but haven't had it that long.
Old Jun 1, 2009 | 09:42 PM
jkchang10's Avatar
In case anyone was wondering about the final result...
I couldn't get the adhesive off. I went to body shops and theyve pretty much said its messed up and I have to get new headlights =(
maaco thinks they could fix it.... for 265 bucks.
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Fireman07603
Aug 9, 2015 06:00 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
attarday
Jul 15, 2015 04:03 PM
