So i walk outside and almost cry..
Old Aug 13, 2009 | 01:48 PM
G35Hokie's Avatar
25mm spacers front and back should make it sit very flush with the .9 inch drop on tein s-techs, correct? Is there a better option spacer wise... Going for the aggressive look.
Old Aug 13, 2009 | 02:22 PM
Nikku-'s Avatar
Hey Hokie,
I don't know if it's too late but if it's paint you could try Langka blob remover. Removes paint and not clear coat when I do touch ups and it works really well.
Cheers,
Nick
Old Aug 13, 2009 | 02:47 PM
Darkstar752's Avatar
I would go more for a TA look if you're powdercoating, try a thin line. If you do the entire lip it's going to be a big fat helping of silver which doesn't look that good IMO.
Old Aug 14, 2009 | 10:39 AM
G35Hokie's Avatar
Well after meeting with the guy that will be doing my powder coating, he showed me examples including a glossy black he did on an escalade last week and I decided to go with the glossy black. At his shop he cant do the chrome inner lip anyway because the bend of the spokes. Where I live his shop is the only options so I guess im going solid black on black. He also recommended doing the brake calipers and discs while he has the wheels off. Not sure if he just wants the business or it would be a good idea. He said he has done some glossy black rims with the silver brakes behind them and looked good.
Anyone have any experience with brake powdercoating? (Pictures if so)
Old Aug 14, 2009 | 11:03 PM
EL-EE-ES's Avatar
powder coat the whole rotor? im not sure if that good, maybe the centers. id powder coat the calipers
Old Aug 15, 2009 | 03:01 AM
itgogitrev's Avatar
Powdercoat the calipers and nothing else, not even the wheels.
You can powder coat cast wheels with no adverse effects. However, powdercoating forged wheels will basically undo some of the forging. Forged wheels are made under thousands of pounds of pressure, heat, and are quenched to lock the basic elements of the alloy together. Putting the wheels under the required heat to cure the powdercoating is like annealing sheetmetal. The molecules 'unlock' and are no longer under pressure, so the molecules are free to set wherever is most comfortable.
It results in a weaker wheel where they may bend or break easier.
Old Aug 15, 2009 | 11:10 AM
Powdercoating temperatures are relatively low. And if that's true, why is the Z wheel that's famous for snapping after powdercoating a cast wheels while I've never, ever heard of a case of a forged wheel breaking?
Thousands of members here have powdercoated their forged wheels with NO adverse affects.
Old Aug 15, 2009 | 06:07 PM
G35Hokie's Avatar
More opinions on this anyone?
I need to be making an informed decision.
Old Aug 16, 2009 | 12:51 AM
Never heard of a case of Rays forged wheels snapping or cracking at all on G's or Z's, and I've been around a while. You can PM members who have powdercoated their wheels, just search for powdercoated.
Just so you know, the bake temps for powdercoating are about 350-400 degrees Fahrenheit, which barely cooks a turkey. It certainly wouldn't be enough to weaken any forged metal. But, get some second opinions just to be sure.
Old Aug 16, 2009 | 05:27 PM
G35Hokie's Avatar
Havent been able to find a case where this has been a problem thus far...
Anyone with any bad experiences?
Old Aug 16, 2009 | 06:22 PM
kregg's Avatar
Aluminum materials which ends with a T6 or other number are essentially heat treated (6061-T6, 7075-T6). Find out the composition of your wheel. Those temperatures are hot enough to affect the microstucture of heat treated alloys, might not be significant enough to cause an issue. But I would not powdercoat wheels, or rotors.
I thought I heard there was a powdercoat material that cured at 250 deg. F. That would be safer.
Old Aug 16, 2009 | 06:41 PM
Lmoye's Avatar
looks to me like brake fluid stains. thats just me
Old Aug 17, 2009 | 12:59 AM
itgogitrev's Avatar
Opinions are welcome, but I'll throw you a fact or two.
Bare aluminum has a melting point 1220 degrees F. The wheels aren't complete aluminum; they are alloys but the main temperature properties aren't altered that much. Without getting into too much detail (and in an effort to not bore you), here's straight isht.
When you get into the upper 2/3rds of that temperature range, the grain of the alloy starts to 'flow' from its cold or hot worked grain structure. In simpler terms, the tightness of the grain structure starts to loosen. When you get to about half of the melting temperature, nearly all of the benefits of the forging process have been baked out.
Another reason why I'm going into a ton of detail is because we don't know the alloy spec or what type of forging method Rays uses. However, most hydraulic press forging temperatures range from 600-800 degrees F. There's your half of the melting point. Once the alloy is pressed, the grain structure is very tight and dense. But if you allow it to cool naturally, the grain loosens and it only marginally harder/stronger then a cast wheel. Instead, it's quenched to lock the grain.
When you're curing the powdercoat, you easily get into the 2/3rds temperature range.
If you need a more 'in-person' demonstration, get a piece of aluminum sheetmetal. Most sheetmetal is cold rolled, which isn't nearly as complicated or beneficial for strength as forging; it's mainly to control the quality and quickly set the thickness of the sheet.
Take your sheetmetal and try to bend it. If you can, okay. If not, that's even better. Now take that sheetmetal, put it in the oven at 400 degrees F (bottom of the 2/3rds range) for 20 minutes. Take it out, let it cool and try to bend it again.
Keep in mind, that's only the cold-rolled working being baked out. The same thing will happen with forged wheels.
If I was flipping burgers, a bank manager, or a **** star, I wouldn't expect you to take me seriously. But I'm an mechanical engineer/industrial designer and I deal with this stuff DAILY.
Old Aug 17, 2009 | 09:25 AM
G35Hokie's Avatar
Thanks... i went to school to be a bank manager and a **** star so your right I will be taking your advice on this one.
Old Aug 17, 2009 | 09:28 AM
  #30
G35Hokie's Avatar
THIS is very very interesting and something I hadnt thought of. I have been having problems with the clutch sticking in hot temperatures (Sticking halfway after disengage)...
Already have the stainless steel clutch line ready to go in, just waiting on the Dot4 Brake fluid i ordered in effort to fix this problem.
What could be leaking/broken that would get the brake fluid from the clutch to the wheel?
