20% Off Lake Country Products & Accessories thru end of August
Old Aug 23, 2009 | 10:21 PM
Detailed Image's Avatar
Take advantage of 20% Off ALL Lake Country products through the end of August. Lake Country is well known for making some of the best buffing pads in the industry and now you can save BIG.
Don't forget about the other Lake Country products, we listed some of our favorites below:
Tire Dressing Applicator - Very durable and easy to use
Blue Grout Sponge - Very safe, durable and high quality wash media
Red Foam Applicator Pad - Our softest hand applicator
Snappy Clean - Citrus based pad cleaning formula
If you have any questions or if you would like any products recommendations please let me know!
George
Old Aug 23, 2009 | 10:40 PM
Xet's Avatar
Xet
how big is that tire applicator?? its such a pain using applicators on my oem 19s that are really wide and either run into my fender or onto my rims (i am lowered though)... it seems like most applicators are made for standard cars on the road without low profile tires, would you say this one is well suited for the g's tires?
Old Aug 24, 2009 | 05:36 PM
The LC tire dressing applicator is probably going to be larger than low profile tires. The way this particular applicator is designed is it's a very durable foam with slits down the middle to allow for 1 side to be gripped without getting product all over your hands and the other side to apply the dressing. Essentially what I do with low pro tires is only apply the dressing on half of the applicator pad and use that side. The upside to this applicator pad is it's extremely durable compared to others I've used in the past.
My best recommended technique for applying a tire dressing is to invest in a smaller 4 oz pump spray bottle, load it with your choice of dressing. Mist it onto the tires, then go back and wipe the tires with the applicator to work it in evenly. To me, this provides you with the most uniform finish and minimal sling.
Hope this helps.
George
nightowl.czc
SouthEast
Aug 28, 2015 08:36 PM
Team STILLEN
Aug 10, 2015 08:17 PM
