best tire shine?
Old Oct 6, 2004 | 05:00 PM
east1999bt's Avatar
Re: best tire shine?
I am using zaino tire glass right now and i'll be changing after i finish this bottle because it just doesnt last long enough, its not "wet" looking enough for my standards, but other than that its OK, and i like the fact that its not oily. but I'd recommend something other than zaino tire glass for your tires.
Old Oct 10, 2004 | 04:37 PM
jlrharley's Avatar
I have tried spanking the monkey!
Old Oct 13, 2004 | 08:45 PM
G35_Foo's Avatar
so is spitting monkey any good im thinking about ordienrg? ive been using meguires tire gel (purple stuff) but it flings like i just came home from the track on top of that i wiped off the excess wiht paper towels and it flings.... Eagle one Clear tire shine its good and it does fling but u cant see it untill dust or dirt touches it then its just like the meguires.
so i need help in this also what is good.. tell people to make more post..
04 G35 Coupe 6 MT Ivory Pearl/Navi/
Old Oct 17, 2004 | 03:52 AM
Nodnero's Avatar
I use Meguiars High Performance. Purple gel that lasts for 2 weeks and doesnt get dissolved by water. Can spread it for light darken, or just apply for the "new tire shined" look
Old Oct 19, 2004 | 05:11 PM
SLiM003's Avatar
I use vinylex on my tires and don't get slings. It darkens the tire and make it look new. I use it on cars that want a new car look. I always apply 2 coats everytime. For a higher gloss I vote for meguiars endurance gel (purple one). I use it with a foam pad from eagle one. I pour a thin line on the pad and let it soak on the pad for a couple seconds. Then apply it thinly on my tires. for a higher gloss apply a 2nd coat. After letting it dry (aprox. 10 min.) I buff the tires with a cotton towel to remove excess to prevent slings. Always make sure not to put too much product on the tires. It'll make it harder to buff and the product will get into the crevices between the treads that causes slings when you drive off.
Old Oct 20, 2004 | 11:43 AM
GCoupe35's Avatar
When i went to the dealer they told me these little sprays that people use to shine thier tires will eat through the tire.
Is this true? When i went for my maintenance i was talking to the Detailing people who have expierence with it.
Old Oct 20, 2004 | 12:53 PM
wizawuza's Avatar
i really doubt it.. the black magic stuff I use is just a silicon substance which gets into the sidewall, and then becomes slick, so that dirt and whatnot doesn't stick.
But then I'm not exactly a chemist so I dunno.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Oct 20, 2004 | 04:48 PM
SLiM003's Avatar
Some rubber and plastics are sensitive to products that contains silicones. Most materials that are made these days aren't that prone to browning or degrading as much as before. If you want to make sure you're on the safe side. Use something that is water- based and doesn't contain solvents or silicones. The only downside on water based formula is that they are not as durable as solvent based.
Old Oct 22, 2004 | 01:54 PM
ckg35's Avatar
Meguiars for me as well. The sponge makes applying quick and easy, and there is less sling.
Old Oct 31, 2004 | 01:14 AM
mikeinaustin's Avatar
i've used them all and like zaino's the best. but it isn't just for tires, its for any plastic trim pieces (well black and gray ones really) on the outside of the car you would like dressed up.
Old Oct 31, 2004 | 08:57 PM
BirdMan's Avatar
By far te easiest product to use that looks great is Black Magic Tire Wet Foam (make sure you get the foam!!!!). Just spray it on and viola, no rubbing or anything! I'm also a huge fan of the Dupont Teflon Car Series products, the stuff genuinely works and lasts a long time!
Old Nov 22, 2004 | 01:01 PM
blksnake's Avatar
I use Meguiar Gold Class Tire Gel and I'm very pleased. I use a small sponge like applicator to put it on evenly.
Results last for over a week.
BLKSNAKE - '04 G35 Coupe
http://hiddensub.info [img]/w3timages/icons/laugh.gif[/img]
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
philthethrilloh
Sep 9, 2015 01:25 AM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
