WORM on my fender dried up and hardened. Cant get it off!!
Old Sep 24, 2009 | 04:50 PM
04GcoupeSilver's Avatar
So im gonna do a mothers scratch removal and 3 stage wax tommorow, and on my passenger side fender i got what looks like whats left of a worm and it hardened on my fender. I tried bug and sticker remover but the bugger wont come off. Any other suggestions before i start waxing?
Old Sep 24, 2009 | 04:51 PM
JIle342's Avatar
goobgone works wonders..
Old Sep 24, 2009 | 04:52 PM
JIle342's Avatar
or you could take a hair dryer/ heat gun and warm the little dead bugger up and see if its easier to get off..
i treat stuck bugs like i treat my molding and badges.. lol
Old Sep 24, 2009 | 05:02 PM
thescreensavers's Avatar
Mr.202?
Get a Wet Cloth or what not, and hold it on or leave it on and let it soak into the dead worm, then it should be tons easier to clean.
Good luck
Old Sep 24, 2009 | 09:49 PM
Greekboy115's Avatar
I don't think waxing will help your cause as you would just be applying the wax over your worm. I would try googone first as stated above and if that doesn't work give it a go with a clay bar. Be sure to use plenty of lube to keep it really moist as you clay. If all else fails you need to polish not wax. The polish is an abrasive and will wear it down while the wax will just coat over.
Old Sep 24, 2009 | 10:30 PM
snowrider13's Avatar
Fight worm with your worm, Pee on it!
Old Sep 24, 2009 | 10:47 PM
ryno824's Avatar
^^ He said plenty of lube for your "WORM"
Old Sep 26, 2009 | 05:10 PM
well crappy deals, i got the worm off gently, little ****er took some of my paint off too. crap...oh well least the worm is gone, could always get touch ups. thanks for the help guys
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
alexbenz
Sep 26, 2015 11:30 AM
toadfire
Sep 21, 2015 07:15 AM
TeamNoSleep
Sep 13, 2015 07:40 PM
