TINT PROBLEMS
Old Aug 11, 2004 | 05:55 PM
GG1RL's Avatar
TINT PROBLEMS
Does anyone have a colored vinyl strip on the back window to cover the dot matrix where the tint wont stick?? If u have pictures, please post them.
Thanks
Old Aug 12, 2004 | 01:06 PM
CR8IV's Avatar
Re: TINT PROBLEMS
I installed a piece of black vinyl that I got from a local sign shop (1' x 4' = $25). My so-called "proffesional" window tiniter swore up and down he could get the tint to stick. After a day the tint began to lift. I removed the tint about a half inch from the bottom of the matrix. Cleaned off the residual adhesive. I then took a couple of piece of paper and traced the inside of the window and then transferred it to the piece of vinyl. The entire process took about an hour. Use a press card to avoid air bubbles (work from the center out). It also helps to have a extra pair of hands. This first shot is from the outside. Please excuse the dirt (Thanks Charley!)
Old Aug 12, 2004 | 01:08 PM
CR8IV's Avatar
Re: TINT PROBLEMS
A shot from inside. When looking in the rear view, it is barely noticable. Hope this helps.
Old Aug 12, 2004 | 01:16 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Re: TINT PROBLEMS
GG1RL,
I'm here in California, however the Tint guy I used told me today that he has this special "Black Vinyl" he uses on Dot Matrix.
| 04 Twilight Blue 6MT | Aero w/ Spoiler | Pop Charger | Cornell Custom Rims | Falken Tires | Front-245/40/18 , Rear-275/40/18 |
GNATION
Old Aug 12, 2004 | 03:07 PM
GG1RL's Avatar
Re: TINT PROBLEMS
how do u think it would look if i matched a vinyl strip with the color of the car (brilliant silver) on the outside??? Ive got 20% tint on the back window, if i went with the black strip on the inside would u be able to tell from the outside??
Thanks for the help!
<P ID="edit"><FONT class="small"><EM>Edited by GG1RL on 08/12/04 12:12 PM.</EM></FONT></P>
Old Aug 12, 2004 | 03:34 PM
CR8IV's Avatar
Re: TINT PROBLEMS
I was originally going to go that route and put the vinyl on the outside. It then dawned on me, I live in SoFla which is approx a foot away from the sun and relized that after a couple of months in the sun, it would fade and look like *****. The sign shop I use, has dosens of colors of vinyl. I would check out your local sign shops and see if they can give you sample to match the car. IMO I would go with black on the inside. The benefits of a black car, all blacks match it.
Old Aug 12, 2004 | 03:37 PM
CR8IV's Avatar
Re: TINT PROBLEMS
Another shot from the front. If you can't tell, I have 5% all around with 30% on the front.
Old Aug 12, 2004 | 05:35 PM
GG1RL's Avatar
Re: TINT PROBLEMS
Ok thanks!!
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
gatorglaze
Sep 10, 2015 12:03 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
