Need help making a custom paint job glossy (shine) [PICS]
Old Nov 23, 2009 | 11:51 AM
simpson's Avatar
Originally Posted by 4DGS
I would have stripped the paint and redone the prep. That was not prepped at all.
Look at it like this, for every 10 minutes you spend spraying the piece, you need to spend 1 hour prepping it.
Sand it down and start over.
Where is the bad prep? It is the way the clear comes out of a spray can. Bad prep does not give you orange peel. Bad prep give you paint flaking off.
Old Nov 23, 2009 | 12:28 PM
cpufreak3's Avatar
Hmm, yeah. I did clean and sand it down with 400 grit paper.
I used adhesion promoter after that, then some flexible primer, wet-sanded smooth. Then black with wetsanding between two coats. At this point, the lip looked perfectly fine.
I think simpson is correct in the fact that it's the way clear comes out of a can.
I'm pretty sure the prep job was fine because the paint has held up even with me flexing and installing the lip.
By the way, I followed this guide: http://forums.s2kca.com/showthread.php?t=15600
If you look at his final pictures, you can see it also doesn't have the reflective finish (his is silver though so it's not as noticeable).
Old Nov 23, 2009 | 01:04 PM
4DGS's Avatar
I know for a fact you can make clear coat come out of the can smoother than that. When I get a chance I'll post a photo of the wheels I just sprayed.
OP, what clear coat did you use?
Obviously it's not going to come off you uses adhesion promoter, that's sprayable epoxy. Why do you think you need to spray the paint or primer on 10 minutes after the AP has been sprayed? Because the epoxy sets slightly and then fuses to the paint molecules.
I'll update this post later when I'm back to my other computer with the photos on it.
I know you can do better, it's not noticeable and looks totally fine but you can make it look like a shop did it, even with cans.
Old Nov 23, 2009 | 04:28 PM
cpufreak3's Avatar
I used Duplicolor Clear Coat.
What do you mean "it's" not going to come off? The orange peel? Or all the paint?
When I was spraying the clear on both the lip and the grill, I felt that the clear is what screwed it up. Both looked really good before that.
Also, I think that spraying plastic may be different than metal.
As for the wheels you sprayed, can you walk me through what you did? Did you have to wet-sand the clear coat and polish it?
Here's an example I found online: http://www.ehow.com/how_2182233_wet-sand-paint-car.html
You can see how bad the orange peel is before-hand. Maybe he didn't prep it correctly, but I feel that orange peel is going to be there from spray paint in glossy colors or clear coat.
Old Nov 23, 2009 | 05:35 PM
simpson's Avatar
orange peel is from spraying the clear to dry,to close, or to far away from the panel. To wet and the clear wants to run off. Great jobs are hard to do in a spray can. I have worked at a body shop for almost 10 years. This is what i do i can hardly get clear in a can to look nice with out wet sanding. Op i would wet sand and buff if you can or the other thing you can do is sand it back down with 600 grit sand paper (wet) and re clear.
Old Nov 23, 2009 | 05:41 PM
cpufreak3's Avatar
You don't think reclearing will have the same problem? Or how should I avoid it?
Also, what do you mean by too dry? I'm not supposed to let the clear dry between coats?
Old Nov 23, 2009 | 07:02 PM
simpson's Avatar
By to dry i mean the clear was sprayed to light and not enough was applyed. I would practice spraying something else to get a feel for how the clear comes out of the can. Try moving slow to fast sweeps to see what looks better. Closer and farther away from the panel also will affect how it comes out. I dont know about the can clear but at work flash time between coats if five to ten mins depending on outside temps.
Old Nov 23, 2009 | 10:25 PM
4DGS's Avatar
Simpson has it right. What the orange peeling means is that the clear coat didn't go on evenly. You need to get a more even spray and maybe a little thicker. It needs to be close to the point of dripping or running but definitely not running. It took me a couple trys to get the perfect spray.
Turns out I don't have the photos at home either, the wheels are at the shop so I'll take some when I'm there tomorrow.
Old Nov 23, 2009 | 11:02 PM
cpufreak3's Avatar
Did you use duplicolor?
And if do get an even coating on, will I still need to polish or sand it to get the reflective/mirror finish?
Old Nov 24, 2009 | 10:58 PM
simpson's Avatar
a very nice even coat will not need to be polished. You can sand it down with 1000 grit sand paper and just reclear.
Old Nov 25, 2009 | 01:19 AM
4DGS's Avatar
Not gonna lie, I didn't even sand between coats of clear.
Old Nov 25, 2009 | 01:23 AM
cpufreak3's Avatar
Hah. Did you have to polish after the final coat of clear?
Old Nov 25, 2009 | 05:24 AM
4DGS's Avatar
Nope, I'll get the photos up by tomorrow. I continually forget.
Old Nov 25, 2009 | 01:57 PM
4DGS's Avatar
I suck at pictures.... I'll get my brother to get legit ones.
As you can see very little orange peelage. I'm sure I could have done it better had I sanded between coats but I was fed up. I used the same duplicolor clear coat as you I believe (wheel coating correct?)
Old Nov 25, 2009 | 04:30 PM
  #30
simpson's Avatar
You can not sand between coats of clear you need to let it dry for 24 hr before you can do that. Your wheels came out looking nice.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
newg37
Jul 26, 2015 09:32 AM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
bickfordbft
Jul 20, 2015 07:57 PM
