polished plenum
Old Feb 13, 2010 | 05:21 PM
kennymo's Avatar
polished plenum
What method is used to polish the upper plenum to make it all shiny. Can someone explain how to do it please
Old Feb 13, 2010 | 08:04 PM
4DGS's Avatar
I suggest you take it to someone if you have to ask, because it is a lot of work.
You're going to need to sand it, then buff it on a buffing wheel. remember all those little lips? Yup, enjoy those.
Old Feb 13, 2010 | 08:21 PM
alfhasg35's Avatar
its worth it to buy it from SxExCx...he is a vendor on the forum... by the time you get frustrated enough to buy one, you will have wasted 10hrs...
Old Feb 13, 2010 | 08:23 PM
SxExCx's Avatar
This is a HUGE DIY job. Lucky for you, I am running a special with big savings.
Check it out and PM me if you are interested.
FYI, I have worked on most of the high profile cars on this (and many other) forum.
https://g35driver.com/forums/group-b...-dress-up.html
Old Feb 13, 2010 | 10:06 PM
kennymo's Avatar
i love your stuff but honestly i would like to give it a try myself. i completely understand that is hard and not a beginners project. but i have to start somewhere. i watched some videos on youtube on how to do it. and now i have some questions.
is the upper plenum aluminum? or what kinda metal is it? also. what compound should i use?
Old Feb 13, 2010 | 10:11 PM
SxExCx's Avatar
Yes, it is aluminum. There is special polishing compound for aluminum, just google it.
Old Feb 13, 2010 | 10:12 PM
kennymo's Avatar
ok thank you. if i **** up or get tired of it i will be contacting you for one haha
Old Feb 13, 2010 | 10:14 PM
SxExCx's Avatar
lol
I'm here if you need me
Old Feb 13, 2010 | 10:16 PM
kennymo's Avatar
thanks. do you know of any local stores that would sell the compound?
Old Feb 13, 2010 | 11:12 PM
SxExCx's Avatar
I'm not local to you so I have no idea.
Old Feb 13, 2010 | 11:36 PM
cc_brandon's Avatar
Someone posted a link to a DIY somewhere on here, I'll see if I can dig it up. I was in the same position as you a couple months ago and ended up doing the upper plenum myself. I ordered a kit from Caswell. Not really sure how long it took, I'd say at least 10 of the most boring hours I've ever spent to my car. Needless to say, I'll definitely be having someone else polish the rest of my parts when the time comes haha.
Old Feb 14, 2010 | 11:54 PM
Tollboothwilley's Avatar
I don't know how Sean can make these worthwhile to do. My technique and tools must suck. Its A LOT OF sanding.
Sean, do you use blue magic after the sanding or do you throw it on the buffing wheel, or both?
You should really just consider picking up one from Sean, or buy a spare to do in your free time if you really wanna try it out. (I have one for sale...not worth my time since those little areas are so hard to do )
Old Feb 15, 2010 | 01:35 AM
SxExCx's Avatar
I do almost EVERYTHING on a wheel. The final steps are to clean it and hand-buff it with the Blue Magic.
Old Feb 15, 2010 | 02:47 AM
never gone's Avatar
I'm surprised you like Blue Magic Sean, on a side by side I did on a couple different surfaces, I found Mothers Alum Polish worked a lot better. Whenever I've tried Blue Magic, it left tons of swirls in the metal. I dunno.
Old Feb 16, 2010 | 12:18 AM
what kind of sand paper are you guys using? Are you using a drill with attachments, dremel, or hand sanding all of it?
The emery cloth pads are worthless..they gum up in 5 seconds. The aluminum oxide seem to hold up pretty good but hand sanding seems to make it take about 40 years and completely ineffective for time.
