best way to buff out scratches on plastic???
Old Nov 18, 2010 | 09:50 PM
the_sedan's Avatar
so i took my headlights apart to get the housings painted.....went to wipe them clean before i put them back together....figured a lil plastiX wouldnt hurt with a brand new microfiber polishing rag. wrong. now the INSIDE of my lenses are scratched. one not so bad....very minimal....the other side looks like i took 800grit to it. whats the best way to go about cleanin up the inside of the lenses now? the outsides arent a problem, ill do them as i do every other one. 800, 1500, 2000, cleaner, polish, wax vwalla......help pwease!!
Old Nov 18, 2010 | 09:52 PM
thescreensavers's Avatar
Mr.202?
Your not suppose to touch the insides, there is a coating. I think you need new covers...
Old Dec 5, 2010 | 07:18 AM
Blue Dream's Avatar
I drove ttrank's car solo
That is correct. I don't think you'll get the inside clear and smooth again.
Old Dec 7, 2010 | 11:58 PM
gary c's Avatar
Best headlight polish/cleaner on the market is 3M. You may as well give it a try at this point you have nothing to lose and it will remove all the scratches.
Gary
Old Dec 24, 2010 | 10:51 AM
cookydon3's Avatar
It depends what type of plastic it is. firstly , try get some 'glasspaper' use it the same as you woiuld sandpaper and after the scratches show a little less, get some 'wet n dry' paper. This stuff looks like a black piece of sandpaper however you wet it before you use it. I hope this helps however it depends on the type of plastic.
honda parts car
Extended Warranty
jeffbdye
Jun 1, 2018 03:51 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
dcsbh1
Oct 1, 2015 03:15 PM
vQFamily
Sep 30, 2015 01:17 PM
