Gilmour Foam Master
Old Nov 20, 2010 | 06:56 PM
thescreensavers's Avatar
Mr.202?
Gilmour Foam Master
I used 8oz of Gold Class Soap the rest with warm water.
I used 1-32 Ratio on the gun which is the middle hole.
Old Nov 20, 2010 | 09:00 PM
toymachine2009's Avatar
Sweet. I have that one too and I'm not very happy with it.
Old Nov 20, 2010 | 09:57 PM
Pedrog35's Avatar
thats not a foam gun...my uber gun works better in my opinion
Old Nov 21, 2010 | 12:39 AM
Mr.202?
Oh no why not?
Uber gun? Does it work off the hose? It sure is a foam gun, works exactly like any other, be it a pressure cleaner or a hose. Sure it may not have the same dwell time as the pressure cleaner one can achieve but from the first use today and how much time I saved washing my car. Its good for me.
Old Nov 21, 2010 | 12:51 AM
Mine seems to work when it wants. Sometimes it will look like yours other times it wont soap very much at all.. To get the same soap you have in your picture I have to really put a lot of soap in it just about as much as you would need for a 5 gallon bucket..
I wanna get a foam cannon for my pressure washer to do some serious foaming haha have you seen pics of what those come out to look like?
Old Nov 21, 2010 | 12:58 AM
Mr.202?
^ Yep they put thick foam, only benefit of that, is that you can have it dwell longer. You dont want it too thick either or it wont move.
First off what soap are you using? How many OZ are you putting in? If you put too little it wont foam. You need to look up the dilution levels of the soap you are using.
Also buying soap that is for use in a foam gun will really cut down how much soap you need.
I bought some Meguiars Super Soap its coming in on Monday so I had to use Gold Class.
I can put 4-5oz of that for the whole bottle vs 8 for gold class.
Old Nov 21, 2010 | 01:19 AM
I have tried Chemical Guys Maxi Suds II which is supposed to foam really well and Chemical Guys Citrus wash which is really concentrated to remove old wax instead of harsh dish soap.
Old Nov 21, 2010 | 01:44 AM
Mr.202?
^ yea thous are supposedly good. its all about proper dilution.
Old Dec 15, 2010 | 11:47 AM
gary c's Avatar
With all the information and a kazillion opinions about not using dish detergent on painted surfaces, is there anyone that stupid? My coupe has never seen any kind of soap....except the wheel wells and under pressure.
Gary
Old Dec 17, 2010 | 05:08 PM
Retzius's Avatar
Well I just bought the foam lance/cannon and can't wait to use it. Too bad its raining right now. I will be sure to post.
Old Dec 17, 2010 | 07:43 PM
soundmike's Avatar
I have the same "gun" but noticed it makes better foam if i don't dilute the soap (either Gold Glass or Nano Wash/Wax). I usually only fill-up the Gilmour bottle to 1/4 with soap and usually still have some left after i'm done.
Although, the best foam was achieved after i swapped the hose out for a 3/4" one.
Old Dec 18, 2010 | 11:27 PM
jl114's Avatar
The dilutions are right for the c setting so gold class just doesn't foam up too well. I use to use gold class for good pricing but now it costs just as much as the boutique soaps I get from a local detailing store. I think it is pretty cheap in the states so you could try upping the soap content. I've used CG citrus wash n gloss, maxi suds, optimum soap, duragloss 901 and dp xtreme foam, and all these foam up very well.
Ubergun? If it is the foam gun carried by detailers domain they are made by the same manufacturer and foam up the same.
Old Dec 19, 2010 | 12:12 AM
Mr.202?
heh, if you don't dilute the soap you are using more soap!
I started using Megs SuperSoap I only used like 3 cap fulls and it put out as much as Gold Class did. It also has a much longer dwell time then Gold Class
More Water pressure = more foam!
I bought a Gilmour hose Its Grey and its like 8 layers of latex. Any how it was only 25 bucks for 50 feet at homedepot, and it defiantly has a lager diameter then my old hose, no idea what the diameter is though I threw away the packaging.
Make sure to run clean water before you put it all away, so you dont get any clogging issues.
Old Dec 19, 2010 | 04:10 PM
Gary
WTF I never said I used detergent???
G35xdriver04
Nov 7, 2015 08:31 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
bigmike
Sep 17, 2015 01:58 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
