Help polishing engine bay
more stuff but I dont want to polish it, lol. I did all the sanding by hand and with it on the car just cuz I felt lazy and didnt want to take off all the bolts and bs on it. I spent about 10 hrs so far on it and am pleased with the results. It's good to know I'm the ONLY one with this done on a M and I cant wait to have the rest of the engine bay painted piano black. Then I will have a friend take some pro shots of it all cleaned up and shinny!
Polishing our under hood starting with the plenum isn't something you can do on your G without removing it and having the right tools available. You can do the small parts with a lot of elbow grease but that too is tedious work best left to Sean. (SXEXCX) I polished my Nismo differential cover/cooler cause it looked awful when I got it....light sandpaper....steelwool....compound....dremel....hi gh speed buffer and several coats of clear coat.
Gary
Gary
OMG guys someone halp me please, what did you all use to sand in all those tight small corners where sanding with your finger and sandpaper just does not cut it? i use some cookie sandingwheels with my compressor so everything else, but theres a few spot where im having alot of toubke with.
Help PLEASE :]
Help PLEASE :]
Woops sorry, on the plenum, for example on those areas where all the bolts go for attaching it to the lower plenum. and all those tight areas on the back/side part of the plenum. like it there some sort of special drill attatchment that will help me in this? anyone please give me advice
magnetism80
Feb 1, 2019 10:00 AM
