paints on the tires
Old Jan 23, 2011 | 07:29 AM
whoisthis's Avatar
paints on the tires
How do you remove spray paint on the sidewall?
I was lacking Blue tape when i was spray painting the rims. Got quite a bit of paints on the sidewall.
Thanks.
Old Jan 30, 2011 | 05:52 PM
lechols155's Avatar
i would try a sos pad just keep away from the wheel. did you spray paint the rim with out taping off the tire?
Old Jan 30, 2011 | 06:11 PM
toymachine2009's Avatar
yup light sanding such as scotch bright just lightly rub it against sidewall no pressure needed paint will be off in seconds
Old Jan 31, 2011 | 01:17 AM
whoisthis's Avatar
^^ i don't know what scotch bright is but would any sanding paper work?
Old Jan 31, 2011 | 01:18 AM
whoisthis's Avatar
i did some, but ran out of blue tapes, and couldn't wrap the sidwalls only with papers
Old Jan 31, 2011 | 01:31 AM
yes but be a little harder with sandpaper or fine steel wool would work. Scotch brite is like the green part on the back of a sponge just a little rougher. You can find them at any local automotive store or home depot or lowes..
Scotch bright is always handy to have around atleast for me it is.
Old Jan 31, 2011 | 01:35 AM
Equipped4dr's Avatar
Just throw some gasoline on that **** and wipe it off with a rag. Or soak the rag in gas and wipe off. Just dont get it on your wheel
Or just get flat black paint and spray over it lol
Old Feb 1, 2011 | 02:24 AM
whoisthis's Avatar
^^gas doesn't sound so nice..lol i heard that brake fluid could work
Old Feb 1, 2011 | 11:55 AM
What do you mean gas doesnt sound so nice? that would prob work fine too take a rag and dump it in some gas and wipe your tire down with it.. You make everything a lot harder than it has to be.
idk why you dont listen and just go get scotch brite its a dollar and will take you 30 seconds a tire then your done.. http://www.lowes.com/SearchCatalogDi...t=scotch+brite
Old Feb 1, 2011 | 03:15 PM
REVUPG35's Avatar
laquer thinner... / mineral spirits... / or an aluminum wire brush like the ones used in the kitchen....
jsimonk
Dec 22, 2023 03:49 PM
zoop425
Mar 29, 2016 05:51 PM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
derres
Aug 28, 2015 03:27 PM
realtalk21
Jul 20, 2015 09:07 AM
