bryansbestwax vs Lexus IS 300 (B/S hackjob)
I was contacted by the owner of this Lexus ES 300, to fix up the body shop debacle of a repair they did to his hood and fenders, as well as polish up the rest of the car to make it look better. The pictures you will see at the start will shock you, those are “finished repairs”.
I started with an ONR wash on the outside. I then clayed the car with Werkstat Blue clay, which came out pretty clean as the owner clayed it late last year. I started by tackling the hood with Optimum Hyper Compound and a foam compounding pad. The hood took 3 passes to rid the hood of all the sanding marks, leaving only the DA sanding curlies that were very deep. The hood was then followed up with Optimum Hyper Polish and then Super Finish to get rid of the micro marring that was left after polishing. The rest of the car was finished with Optimum Hyper Polish and a few other polishes. The LSP was a prototype wax and precleaner from Eshine.
The start
Fenders were is rough shape as well.
I start by spraying the compound on the hood
But then figured out it was better to spray on the pad itself
The compound spits a bit, but does not dust at all.
After a few passes of Optimum Hyper compound
I had a hard time focusing on the 50/50 on the trunk, but the right side is polished.
Used these for LSP process
And the finished pics
All work was done outside in -2 degree weather.
The start
ya, the sun was getting low when I finished, the hood still had some deep DA sanding marks here and there, but other than that it cleaned up nicely. We didn't want to get into wet sanding due to cost.
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
