a few claybar questions
Old Nov 24, 2004 | 10:23 AM
mikeyg's Avatar
im in ny and its getting cold out..i have off friday so i wanted to wash, claybar, and wax my car but i have 2 questions
1) its supposed to be like 45 tomorrow, is that too cold to claybar or does temp not have an effect besides me freezing my a** off
2) i have about 6 coats of meguiars carnauba wax on my car so far, should i dawn wash it and take it all off or just wait and do all this when it gets warmer
Old Nov 24, 2004 | 02:30 PM
Diesel1's Avatar
Moderator
Re: a few claybar questions
If you use carnauba, more than likely you don't have 6 coats left on the car. It tends to fade quickly over time. I would probably say to skip the clay since it will remove all the wax remaining and just wash, clean, and add a few more coats of wax. Save the clay for the spring whenn you will strip it all down (what's left after the winter) and start over. I would say the more wax you build up before winter the better, but those are just my thoughts.
www.gsquad.org
Old Dec 4, 2004 | 02:11 PM
G35_4EVR's Avatar
I have to agree with Diesel. You want to keep as much wax as you can on your car for the winter. Man, I don't miss those winters.
Old Dec 28, 2004 | 04:09 PM
g35detailer's Avatar
I would say it depends on how much time you have on your hands and can you get a nice warm dry place to do your work.
From a comfort point you will likley have frozen fingers and the clay will be near rock hard. This will likley cause you to rush your job.
How about adding a couple more layers of wax over the winter and when it gets warmer out give it a full clabar and polish topped off with your wax of choice.
Also get a good quick spary detailer to use after every wash to add back a little bit of protectant each time you wash.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
