My Meguiars Headlight Restoration results
Old Jul 29, 2011 | 09:50 PM
Kayzer Soze's Avatar
Headlights looked foggy and a bit of yellowing (along with alot of little scratches), so decided to give the Meguiars restoration a try, and am pretty happy with the results
I taped around the lights, wet sanded with 600 grit sandpaper (it was the highest grit i could find), and used a cordless drill on high to do the buffing....note that if you already have the buffing drill bit, just buy the PlastiX cream (bigger bottle) for 12$ instead of the whole kit at 25$.... heres what it looks like
EDIT: I took the advice of the other members, and found a friend who has 2000 grit sandpaper and a 10,000rpm drill..... result were even better (see two last pics)
Attached Thumbnails My Meguiars Headlight Restoration results-photo.png   My Meguiars Headlight Restoration results-photo2.png   My Meguiars Headlight Restoration results-photo.jpg   My Meguiars Headlight Restoration results-photo-2-.jpg
Old Jul 29, 2011 | 10:20 PM
Dubi2087's Avatar
looks good.
Old Jul 29, 2011 | 10:26 PM
VincenzG35's Avatar
I think it comes better by hand in gonna put up a DIY soon
Old Jul 29, 2011 | 10:27 PM
VincenzG35's Avatar
Also why do the pics have special affects
Old Jul 29, 2011 | 10:49 PM
what do you mean?
Old Jul 29, 2011 | 10:57 PM
VincenzG35's Avatar
Look at the side markers and the whole picture its has some type of photo shop tool or something on it
Old Jul 29, 2011 | 10:58 PM
Dubi2087's Avatar
The car just looks like it was clean in the second pic.
Old Jul 29, 2011 | 11:39 PM
i dont see what your seeing, i used my iphone to take pic, and did a screenshot of pic to put it into png...
i watered down the car since the compound splattered a bit onto the hood....
Old Jul 30, 2011 | 02:25 PM
AuAltima3.5's Avatar
Old Jul 30, 2011 | 04:27 PM
19kdrill's Avatar
I'll bet if you go back and follow it up w/ 1000, then 1500 then 2000 grit, you'll see a world of difference.
Old Jul 30, 2011 | 05:16 PM
VincenzG35's Avatar
Exactly what I'm sayin 19kdrill I restore peoples headlights on the side I wouldn't use 1000 though he should do 800-1000-1500-2000-2500 and not skip a grit so he's rid of all if not most imperfections. I also hope you wet sanded. I'm not trying to be mean ,just trying to give advice because that's really bad lol I usually start with 1000 when I do cars and go up to 2500 plastix and then restoration sealer with all new rags
Old Jul 30, 2011 | 05:17 PM
ya, ill keep any eye out for higher grits for next time..... though i figured since the 3M kit comes with 800 grit at highest, that 600 wouldnt be too far off
Old Jul 30, 2011 | 06:01 PM
PAIXAO's Avatar
600 grit is a very rough paper. I agree, go over again and work your way up from 1500 to 2500, then polish.
Old Jul 31, 2011 | 12:34 PM
i took your advice, and found a friend who has 2000 grit sandpaper and a 10,000rpm drill..... result were even better (see two last pics)
Old Jul 31, 2011 | 03:17 PM
VincenzG35's Avatar
Nooo u have to use them all bro 1000 then sand with 1500 then 2000 then 2500 lol
