Any recommendation Headlight Restoration Kits?
Old Nov 16, 2011 | 05:01 PM
tommyz9's Avatar
Any recommendation for Headlight Restoration Kits? My head lights need some. Thanks in advance.
Old Nov 16, 2011 | 05:09 PM
P10 WRC's Avatar
the 3M kit worked the best for me, although it did leave a few swirl marks
Old Nov 16, 2011 | 11:33 PM
Adil_G35's Avatar
go to your local walmart store...those are decent.
Old Nov 17, 2011 | 06:04 PM
LakeShore_Slate's Avatar
megs ftw
Old Nov 17, 2011 | 06:12 PM
redpearl99's Avatar
From what I hear 3M is better than Meguiars
Old Nov 19, 2011 | 12:10 PM
hdsupercrewf150's Avatar
I just de hazed my headlights with meguires. Came out great. Only difference I see with 3m is They have a drill attachment that can be used with the sandpaper and wax. Meguires only has the attachment for the wax. Although I paid the extra $2 and the kit came with a sanding holder that is ergonomicly shaped to your hand that makes it easier to sand.
Old Nov 20, 2011 | 11:56 PM
Digi7ech's Avatar
I used the 3m kit last weekend. Great results from it.
I have a few swirl scratches from where I may have held it too long or hard on the first grit pass.
I should have spent more time on the second level grit trying to smooth those out.
Old Nov 21, 2011 | 10:43 AM
Detailed Image's Avatar
My answer depends on how bad the lights are and your expectations. Here are three kits I'd recommend:
DI Packages Headlight Restoration Advanced Kit
Meguiar's Headlight Restoration Kit
Meguiar's Heavy Duty Headlight Restoration Kit
We also have several articles here about the headlight restoration process using various product combinations - http://www.detailedimage.com/Ask-a-P...eadlight-care/. After checking out some of these articles and kits let me know if you have any questions.
Greg @ DI
Old Nov 21, 2011 | 02:18 PM
Stryde's Avatar
^Good answer right there.
Old Nov 24, 2011 | 05:12 AM
marhew's Avatar
Absolutely 3m kit is works great .
Old Nov 28, 2011 | 10:08 PM
67Fastbackfan's Avatar
If yours look as bad as mine, (mine looked absolutely horrible), I recommend a little more evasive action; if you're up to it. I did mine on my own. Wetsanded with with 1000 - 8000 grit sandpaper, 4 passes with polish and 4 passes with wax. You wont be able to feel your arms but once you see the results it's well worth it. They'll look better than new.
Old Dec 25, 2011 | 10:56 PM
S2KrxRX7's Avatar
Ive used the Meguiar's and it did a decent job, but hazed up again in a few weeks ....
Old Dec 26, 2011 | 06:49 AM
TOGWT's Avatar
Glass Polishing Methodology
• Clean glass to remove dirt, dust or road grime from surfaces
• Use masking tape to protect windscreen rubber sealing
• Apply clay (Magic Clay®) and lubricant solution (WooliteTM / Water 5:1) onto the glass surface (Do not apply to plastic as dulling may occur.)
• Apply a quarter (coin) size amounts of CarPro CeriGlass and an LC Glass polishing pad, is made of dense polyurethane foam with very small cells. The pad’s density enables it to keep the glass polish on the surface, rather than soaking into the foam. You’ll use less polish to get the job done, despite its density; the pad still has plenty of flexibility to conform to the curvature of the glass, speed #4 on a PC random orbital polisher
• Heat caused by abrasive polishing can soften and damage glass; foam pad and product used must minimize heat build-up. Since glass is a poor heat conductor any friction heat built up from polishing must be kept to a minimum by using sufficient product and regular misting of both the polishing pad and glass surface with distilled water.
• Apply to half of the windshield, polishing first in an up and down motion then in a left-to-right motion and then repeat on the other side, proceed to other glass surfaces.
• Go over the glass several times in each direction, glass will polish virtually residue free.
• Wipe off any residue, and polish with a clean dry 100% cotton Micro fibre cloth.
• Inspect glass for clarity and smoothness. Repeat if necessary.
Old Mar 31, 2012 | 01:40 AM
threatcon07's Avatar
That would be a nice guide if our headlight lens were made out of glass
Old Mar 31, 2012 | 09:23 PM
RADRaze2KX's Avatar
Here's a guide with our car as a model .. I used Meguiar's headlight restoration kit
jsimonk
Dec 22, 2023 03:49 PM
Jusseth
Sep 13, 2020 12:25 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
RA081024
Aug 18, 2015 07:03 AM
as25656800
Aug 9, 2015 07:25 AM
