Zaino Over Clear Bra?
Old Dec 25, 2004 | 11:31 AM
FLFIRE's Avatar
Question Zaino Over Clear Bra?
I have clear bra and this will be my first Zaino application. Are there any concerns or things I should look out for with using the Zaino over the clear bra?
Have a great holiday!
Tony
Old Dec 25, 2004 | 06:45 PM
copbait's Avatar
Tony
Nah, just Zaino right over top of the clearbra, even do your wheels! Make sure you do the Z6 also, I put a few coats on the rims and the dust collection effect was reduced dramatically.
Old Dec 25, 2004 | 08:54 PM
TCFOOL's Avatar
Yeah just do it.. I used to use Zaino and put it on everything as well.............
TC
Old Dec 26, 2004 | 12:09 PM
WildWildWest's Avatar
Just make sure it is 'cured' - been on for a month or so. then go over it - just be careful around the edges so as not to snag part of it. run over the edges with a qtip and you are golden
Old Dec 27, 2004 | 07:09 PM
neffster's Avatar
Just do it! It works so well that the bugs will simply wipe off with a dry 100% cotton towel.
Old Jan 7, 2005 | 04:33 PM
jeffreymp's Avatar
I'm expecting delivery of my 6MT on the 21st and am planning on installing a clear bra as well as Zaino immediately upon purchase...
Would it be ideal to apply Zaino and then install the clear bra and then apply Zaino again over the bra? Or is okay to install the bra and then Zaino over it? I've seen some folks emphasize that Zaino should be applied after the bra has "cured"... Any real-life experiences?
I appreciate any feedback you guys might have. Thanks.
Old Jan 8, 2005 | 09:38 PM
Premier's Avatar
You wouldn't need to apply Zaino before clearbra application. If you're installer does what he's supposed to do, he'll remove all of the wax / sealant on the surface before installation. You will need to apply some type of wax / sealant over the film about a wk after the film is installed.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
