How much to replace hinges and scratches?
Old May 30, 2012 | 07:28 PM
NyCrAzY's Avatar
My hood doesn't open properly because it hits against the fenders on both sides. So I am assuming both my hinges need to be replaced.
Also, I have a scratch in the front bumper.
I called the Infiniti dealership and they told me to take it to an Infiniti Certified auto body repair shop.
In your guys opinion ... how much do you think I'll be charged for all this with labor?
I reside in Northern VA if that makes a difference or not.
Old May 31, 2012 | 11:31 PM
Envious Eric's Avatar
whatever the shop charges...what we say doesnt/isnt going make a difference...you should get a few quotes from different bodyshops
cost of hinges
labor to remove and reinstall
bumper repair, prep, repaint, sand and polish
probably in the 1K range
Old Jun 1, 2012 | 11:45 AM
V's G's Avatar
I think each hinge cost about $50, so $100 for parts. You can probably just have your mechanic replace those parts instead of an auto body shop as it might run cheaper, or you can do it yourself. It will probably just take an hour labor for that. For the scratch, is it something you can try touching up yourself first to see if you can live with?
Old Jun 1, 2012 | 12:13 PM
thescreensavers's Avatar
Mr.202?
You have to unbolt the fender and pull it back some, its very labor intensive. There is a DIY on here
Old Jun 1, 2012 | 12:14 PM
NyCrAzY's Avatar
Ive been trying to find the DIY but no luck unless Im typing something wrong.
Old Jun 1, 2012 | 12:25 PM
Mr.202?
^ here
Old Jun 1, 2012 | 01:23 PM
NyCrAzY's Avatar
Thanks man.
Looks like the problem with my hood is the fact each.time i try to open.it, both ends stay below the fender so I have to lift both corners of the hood over the fender to avoid contact.
After opening, I sprayed some wd40 but no luck ... the hinge doesnt even.look bent or anything
Old Jun 3, 2012 | 01:27 PM
Exceptional's Avatar
I have the same problem with my coupe.
Parts are like $80 for everything.
However, labour is around $400-500.
As posted above, the fenders need to be removed.
Sepsis
Feb 12, 2020 02:05 PM
derres
Aug 28, 2015 03:27 PM
Ray Feta
Aug 20, 2015 08:46 PM
vstypicals
Jul 20, 2015 10:55 PM
