Headlight restoration FAIL!
Old Nov 17, 2012 | 03:21 PM
eklaharn's Avatar
Looks like the previous owner on my G35 tired to restore the headlights and messed up pretty bad. As far as how clean it looks its about a 7 out of 10 but the main problem is.. Theres scratches all over the headlights, both sides (looks like he dry sanded the **** out of it)! I have an idea of what to do to get this fixed from researching on this forum but i want to be exactly sure on what I'm doing since I'm not an expert at restoring headlights. Any advice? Steps i should take?
Old Nov 17, 2012 | 03:25 PM
JOKER's Avatar
CLUB MODERATOR
just wet send it again
Start with 1600 grit and move up to 2000
When sending, send in both directions (up down and side to side) with every step.
Old Nov 17, 2012 | 04:24 PM
dvandriesen's Avatar
You then would need to wax it out with a compound.
Old Nov 17, 2012 | 05:05 PM
eklaharn's Avatar
Yeah i was definitely going to go with a compound. I wasn't sure if i needed to sand it down but i guess I'm going to. Any suggestions on a compound?
Old Nov 17, 2012 | 05:10 PM
JOKER's Avatar
CLUB MODERATOR
you can pick up something simple as Plastix at Walmart or any auto parts store and it should work just fine if it's sanded properly.
Just remember to double up you sanding time every time you go up the grade of sand paper.
Old Nov 20, 2012 | 06:00 PM
eklaharn's Avatar
Just got done fixing the headlights. Didnt take me long at all and turned out great! I started with the a 1500 grit then 3000. Then finished off buffing with meguiars rubbing compound.Name:  IMG_1058.jpg
Old Nov 20, 2012 | 06:29 PM
onevoice's Avatar
That looks crisp.
I have another fail, may be you guys can help?
I used the 1500/2000 grit sandpaper on the headlights but forgot to tape the edge of the lights and now I have this dull ring around them. Any idea how I can get rid of it? Its on the metal portions surrounding the headlight. Almost looks like I got rid of the glossy layer of my paint.
Old Nov 20, 2012 | 07:17 PM
PAIXAO's Avatar
^^ Try some rubbing compound or Maguiars Scratch-X. Top it off with a fresh polish and coat of wax.
Old Nov 20, 2012 | 11:24 PM
Envious Eric's Avatar
the yellowing will come back without proper sealing of them...sealant waxing will not last
Old Nov 29, 2012 | 04:07 PM
BlackG35Shine's Avatar
Check out my headlight restoration thread. Should help for any questions you may have
Old Nov 29, 2012 | 10:53 PM
except the sealant wax isnt going to last/protect very long. The lights will still need to be cleaned regularly. You need something that will replenish the UV protection into plastic like the headlight product from SEM
http://semproducts.com/product-catal...dlight-repair/
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
