Clear Bra and Zaino
Old Feb 16, 2005 | 12:41 AM
scoobybri's Avatar
Clear Bra and Zaino
I'm getting a clear bra put on my G Thursday while it is still new. I was going to hold off on buying it but within 2 days I already have a nice rock chip on the front bumper. No time to waste!
Anyway, Zaino products seem to be THE polish to use. But I have a question...whether you use Zaino or something else, how do you deal with the clear bra? Do you use the polish on it or only around it? Will polish make the bra peel or yellow?
TIA,
scoobybri
Old Feb 16, 2005 | 01:00 AM
WildWildWest's Avatar
After it has cured - a month or so - wax over it for years of good looks! Just be mindful of the edges and don't plow into them and all will be well.
Old Feb 17, 2005 | 11:16 PM
TC1's Avatar
TC1
wild wild west hit it on the head
Old Feb 18, 2005 | 03:10 PM
thewheelman's Avatar
You will find removing the polish from the edges of the clear bra to be the most time consuming step, but the most important if you want the bra to be truely "invisible".
Some have recommended using a q-tip wetted with the Z6. I found this method has only limited success without rubbing too extensively. Too much wiping with the q-tip could, over time, leave a permanent mark.
Carefully using a fingernail to remove the last remaining polish stuck on the edge of the clear bra worked for me.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
