quick zaino question, in the middle of it!
Old Mar 18, 2005 | 01:31 PM
aszatk01's Avatar
hey guys, need a quick answer.
i'm in the middle of zainoing the g and just finished applying my first coat of Z5 then i will buff it off. i want to go right into the next coat (i have the ZFX) but it says to use the Z6 spray inbetween. but if i'm just buffing off the last coat and putting on a new one do i need this? or only if i wait inbetween.
thanks for your speedy answer
andrew
Old Mar 18, 2005 | 01:39 PM
realgone's Avatar
Widdle ya into kindling
Got this from the Zaino website. Skip to 7 then read the whole thing!!!
6. Let Z-5 or Z-2 PRO polish dry at least one hour. Please NOTE: Zaino Show Car Polish works best at 60 degrees or higher. However, it can be applied down to temperatures of 45 degrees. It just will take much, much longer to dry. As much as two to three hours drying time is required if the temperature is 50 degrees or below. Also, If the humidity is high. Longer drying time is necessary. Humidity is a killer on the drying time of Z-2 PRO or Z-5. The moisture in the air hinders drying time up to four times longer than normal. Sorry, but I can't help this. When you try to remove Z-2 PRO or Z-5 when it is still wet. All you're accomplishing is moving it around. Kinda like reapplying it. Also you need to use a LARGE White 100% Bath size towel (please refer to my Tips & Tricks sheet on my web site for the proper towels to use) to remove Z-2 PRO or Z-5. Smaller towels will not work efficiently.
To test if Z-2 PRO or Z-5 is dry and ready to be removed. Wipe your finger on a hazed section. It should immediately come off and leave a crytal clear finish. If it smears, it is still wet. You can leave Z-2 PRO or Z-5 on for hours or overnight if you desire. When it is not humid Z-2 PRO will take anywhere from 30 to 60 minutes to dry. Depending on how heavy you applied it. I have applied Z-2 PRO in the Arizona sun and it dried in approx. 3 to 5 minutes. I have also applied it in 38 degree temperature and it took about 2 to 3 hours to dry. Be patient. It's worth it. Different situations affect drying times. Also, remember you have Z-1 and Z-5 both on the car. That is two products that have to dry at one time. Takes longer. Z-2 PRO or Z-5 does not cotain any oils and once it's dry will never ever look smeary or feel greasy. If you remove Z-2 PRO or Z-5 before it is thoroughly dry and get any smears. Just wipe down the car with a damp cotton towel. This will remove any smears. Don't use Z-6 until you wipe the car down. If you'd like call me and I'll help you out with more info!
Note: If you are using the New ZFX accelerator additive drying time is greatly reduced.
7. After removal of Zaino Z-2 PRO or Z-5. You should wait 24 hours if the outside temperature is under 70 degrees and 6 hours if over 70 degrees, before applying the next coat of Z-5 or Z-2 PRO.
8. Use Z-6 "Gloss Enhancer" spray as per directions, between each and every coat of Z-5 or Z-2 PRO. It really helps give a three dimensional look.
It's antistatic properties will reduce dust and dirt pickup by 60%. Z-6 can be used immediately after removing Z-2 PRO or Z-5 or right before applying the next coat of Z-2 PRO or Z-5. Most of my customers prefer to use Z-6 both, before and after Z-2 PRO or Z-5 for that extra gloss boost.
9. You can switch to Z-2 PRO as soon as you are happy with the way the paint finish looks. Example, no more swirls, scratches etc. It's up to you. Z-2 PRO has higher optical properties than Z-5. You can go from Z-2 PRO to Z-5 and then back to Z-2 PRO as often as you want. Z-2 PRO and Z-5 are 100% compatible and interchangeable. You should always end with Z-2 PRO as the last coat because of its higher optics.
10. The number of coats of Z-2 PRO or Z-5 is up to you. When you reach the level of enhancement you like, normal maintenence with Z-7 Car Wash and Z-6 "Gloss Enhancer" spray is all that's necessary. Naturally apply a coat of Z-2 PRO or Z-5 whenever you feel it is required.
NOTE: One application of Zaino Z-2 PRO or Z-5 will outlast anything in the industry and is all you'll ever need for an average vehicle. However, Multiple coats will achieve an even deeper, wetter-looking, ultra high gloss. Plus higher paint protection. It's up to you....You be the judge...
ALWAYS use only 100% Cotton towels. They must be Made in USA. Brand name (Cannon or Fieldcrest) large white bath size towels.
Old Mar 18, 2005 | 02:23 PM
aszatk01's Avatar
thanks a million...i'll have pics up by 5 hopefully
Old Mar 18, 2005 | 05:41 PM
Gumba35's Avatar
It's 5:40 where are the pics.
chinee
Jun 10, 2024 07:48 PM
Th611
Oct 27, 2015 03:48 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
