calling the gurus
Old Apr 15, 2005 | 05:36 PM
player's Avatar
calling the gurus
hi,
i spilled coffee in my other car, its not leather, its a cloth seat.. what can i use to get the stain out?
thanks.
Old Apr 16, 2005 | 09:23 AM
Punchit's Avatar
303 Fabric Cleaner or 303 Cleaner and Spot Remover work great on stains. I dilute the mix with some water and gently scrub with a good brush. I had an extended cab truck before and a friend spilt and entire coffee over the back seat and it all came out. I then bit the bullet and bought the 303 Fabric Guard which has done a great job at repelling future spills and soil build up. They are all on sale for 10% off here and there are bundle deals as well on those products http://secure.detailedimage.com/Merc...ry_Code=Carpet. Let us know how it works out for you.
Old Apr 16, 2005 | 10:55 AM
player's Avatar
which one do you suggest? the fabric cleaner or cleaner and spot remover? the stain is a bit old now..
Old Apr 16, 2005 | 07:14 PM
Punchit's Avatar
303 Fabric Cleaner would be perfect. It super powerful, I recomend you dilute it as 303 recomends to so it last extra long. When your cleaning the coffee dip your nice and clean brush in some water to help the soil and 303 work together to get all the coffee to the surface and then wipe it off or use a wet/dry vaccum if you have one. Here's the large size of the 303 Farbic Cleaner http://secure.detailedimage.com/Merc...gory_Code=3000. Good luck to you and let me know how it works out for you.
Old Apr 16, 2005 | 07:30 PM
player's Avatar
what kind of a brush should i get?
so basically first, i get some water on the stain, then i brush it for a bit, then add 303 fabric cleaner then brush some more and then wipe it off?
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
