How to remove the REAR BADGES?
Just use fishing wire or even dental floss, heat gun, and just swipe away using the wire/floss. I used goo-gone to remove the leftover glue. Wash/wax when you're done and it'll look clean.
Originally Posted by DOCSG35
I need help on how to remove the rear badges on my '05 G35c-6mt!
I want to remove the "INFINITI" and "G35" badges!
Any advice . . . ?
Any advice . . . ?
Okay, just got all of the left residual adhesive off. It took some 10 minutes to remove. I went to Kragen Auto and got some Stoner's Tarminator.
Now to decide on the "G35" emblem.
Re:
Originally Posted by KYINE33167
i used dental floss and gas to take off the glue
Thanks.
Hey Andy, how long have you had your car? since you just took it off, did you seen any outline? i've had my car for 4 months, and decided to debadge last week, and i can see the fade line...
will it go away?
will it go away?
No it won't go away. You can wax it to temporarily hide it but to actually make it go away you'll have to use an abrasive polish. What has happened is there is an uneven fade in the clear coat. When you use the abrasive polish it will even it out and it will look perfect again. Assuming the outline isn't super noticeable I would say the Poorboy's World SSR 1.0 would do the job. Just apply it with a nice clean applicator I like the microfiber applicators but whatever works for you.
will it go away?
will it go away?I trust your outline will eventually fade away.
unfortunately, i have to park outside.
