Lakeshore slate touch up paint
I was wondering if anyone knew of a site where I could order Lakeshore slate touch up paint. I have done a search on here as well as on google and could not come up with much. Even courtesy parts doesn't have lakeshore slate. Any help would be greatly appreciated.
Lips
Lips
FWIW...
Another alternative is Paint-Scratch.
Haven't used them myself, but others have recommended in the past
Originally Posted by picus112
Just fwiw - the touchup codes will be slightly different based on your VIN. The dealer should have the right one.
Depends on the model and year it was made. I am not sure for all G35's, but I know in '03 there were differences between the paint codes from VINs in the beginning of the year and VINs near the end. For the most part you're right, though.
I'm not sure if '05 DG is all the same, if I had to guess I'd say probably.
Ya - there are some posts about it in this forum, too. it works pretty well if you're just doing a few touchups. You have to follow the directions exactly and have a steady hand, but if you do it right it looks almost perfect when you're done. The only problem I ever had with it is that it can sometimes pop the chips out, but that's rare.
