Cleaning wheels
Old Nov 7, 2005 | 02:28 PM
dcutz21's Avatar
Cleaning wheels
Does anyone know of any wheel cleaner that does not require water to help with the cleaning. I live in an apartment and don't have access to running water. And i have tons of brake dust on my new rims. Thanks for any help.
David
Old Nov 7, 2005 | 03:25 PM
afr0puff's Avatar
Supa Dupa Moderator
Umm.. I don't think anything exists like that. Your best bet would be a small bucket of soap water. Then another bucket for a quick rinse using a sponge.
Old Nov 7, 2005 | 03:36 PM
dcutz21's Avatar
That's what I figured.
Thanks
Old Nov 7, 2005 | 06:33 PM
FrizzleFry's Avatar
Another thing to consider is using an all in one cleaner like Klasse AIO on your wheels. It has chemical cleaners that can help remove some of the grime. Waxes have solvents in them as well and you can use that to clean your wheels. I'd definitely recommend microfiber towels. I'm relatively local to you so let me know if you need towels/products. PM or email me at robin@attn-to-details.com
Old Nov 16, 2005 | 01:33 PM
cfrago's Avatar
This may be heresay but I keep my wheels (OEM) daily by just wiping them down with a soft cloth without anything else. Using aio as a start is helpful. To me the key is nevering letting them get bad. A quick wipe down takes maybe 5 minutes.
Old Nov 16, 2005 | 01:36 PM
hye_G's Avatar
I do the same thing. Last night i took a terry cloth (dry), and wiped the wheels off. The brake dust comes off like nothing, but like cfrago said, dont let them get bad because then it will be a b1tch to clean also it will stain or damage your rims.
Old Nov 16, 2005 | 02:11 PM
JDM 350GT's Avatar
cfrago and hye_G, have you put anything on your rims? (like polish stuff, wheel wax, etc)
Old Nov 16, 2005 | 02:21 PM
Houston G's Avatar
Agree. The wiping daily works.
Old Nov 16, 2005 | 02:54 PM
jojolmnop's Avatar
Wheel Wax works great for me.
Old Nov 16, 2005 | 04:17 PM
XcarGO's Avatar
The first question that we need an answer to...are the rims clear coated?
If they are you definitely do not want to wipe the rims with a dry cloth. Brake dust is like a very fine rubbing compound and will only damage the coating.
I personally use a hose and a lot of soapy water and a dedicated sponge that I only use on the rims.
I have also used a product called "REJEX" its a polymer wax that does not attract as much dust as some waxes and it seams to help when cleaning.
Old Nov 16, 2005 | 05:50 PM
Picus's Avatar
Staff ALUMNI
Poorboys Wheel Sealant + a wipedown with really diluted simple green (20:1) every couple days = profit.
Old Nov 17, 2005 | 08:50 PM
Punchit's Avatar
LOL, I like the formula. Poorboy's World Wheel Sealant is a gift from God. It saves me so much time from removing brake dust that comes flying of the pads at sizziling temps from etching into the wheel. Its reduced my cleaning time in half.
Poorboy's World also makes a product called Spray and Wipe that basically like a waterless wash. You can use it on wheels and I don't recommend it on painted surfaces unless its already very clean.
Old Nov 17, 2005 | 09:32 PM
Diesel1's Avatar
Moderator
Don't be so sure!!!
PM DUCATIGUY and grab some of his DucsMILK! The stuff works great on factory or aftermarket wheels!! It contains break dust cleaner and a polish! Great stuff for your application. I would just do it every couple of days so you don't do it when the wheels are reallllllly bad!
Old Nov 17, 2005 | 09:53 PM
Nine49Kid's Avatar
yeah if you have aftermarket wheels that has clear coat you can ruin the paint if you use wheel cleaners because some of them have aciditic chemicals that will ruin the wheels
Old Nov 18, 2005 | 12:48 PM
cfrago's Avatar
I don't usually put anything on the rims. Once in a while I will lightly put on some spray wax, but I figure ( could be wrong) that my almost daily dry wiping would end up quickly taking off any wax. If anyone thinks I'm wrong, let me know. I most likely would use klasse aio on them.
