Headlights are pissing me off
Old Nov 12, 2005 | 08:02 PM
importroller's Avatar
see, I dont mind cleaning the outside, its the inside that is pissing me off. Its just funny how i never see the Zs with this problem
Old Nov 12, 2005 | 08:04 PM
Jakain's Avatar
I've got an 04 Base Z and have this problem.
Wished I'd clear bra her nowadays.
Old Nov 14, 2005 | 03:16 PM
cynicaL102's Avatar
like others said plastic polish rub on and buff off
hasn't gotten cloudy for a month or two now
but if it's inside, not good to have any moisture in there
Old Nov 14, 2005 | 03:44 PM
waijai's Avatar
i.love.gold
I'm willing to bet it's not on the inside. Regular soap/water will not remove this cloudiness. Just use plastic polish, and it will clear up.
Old Nov 20, 2005 | 03:00 AM
dtg35's Avatar
I had the exact same problem on my headlights. I thought i had haziness on the inside of the plastic also. I used some 3M Finesse-it and it cleared the problem like magic. The haziness turned out to only be on the outside surface and was polished off easily with the 3m product. I had previously tried waxes and other cleaners with no luck. Give it a try.
Old Nov 29, 2005 | 04:04 AM
BLKonBLKG35's Avatar
3M is the way to go. It works well.
Old Dec 2, 2005 | 12:15 PM
jimmykce1's Avatar
I have a 1995 ford Tbird with this problem and I used a rubbing compound and used a buffer to take the compound off. It helped a lot and now its about 90% back to being clear.
Old Dec 8, 2005 | 01:03 AM
vjquan's Avatar
I also thought there was a film on the inside of the headlight, kind of like when you don't clean the inside of your windows after awhile. It's real apparent when the headlights are on. When off, it looks fine. With your lights on, look at the housing. It's pretty nasty. That is until I tried Meguiars Plastx. It really is on the outside!
Old Dec 30, 2005 | 11:21 PM
Ozone's Avatar
Mine are fogged on the inside and look like crap. Has anyone had any luck with a dealer repairing/replacing?? seems to me that they should be sealed so that this doesn't happen.
Old Dec 30, 2005 | 11:47 PM
twitch's Avatar
I have an '04 Coupe and the haze "seems to be" on the inside as well. But it's possible it is on the exterior. I am going to try to clean them up.
If you have condensation in you headlamp housing check this TSB
http://www.infinitihelp.com/Ownershi.../ITB03-051.htm
Scott
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
