zaino vs crystal guard
Old Aug 16, 2003 | 01:46 PM
klez's Avatar
which one provides a better shine, looks etc...
let's say time and cost doesnt matter
I've been using mothers and its not as good as these both
thanx
Old Aug 16, 2003 | 03:39 PM
RamboRami's Avatar
G35driver.com Moderator
Re: zaino vs crystal guard
there is tons of debate over this, its been debated MANY times on this forum, lets just say there is no clear and cut choice, both work great. Just get the one that fits you more.
since time and money are non-restricting factors for you, i would choose Zaino. But make sure you do the application in the correct order/manner. Dedicate an entire weekend for your Zaino project.
Im a firm believer in CG, but thats because i am tight on time. Takes me only about 45 minutes to wash and CG the entire exterior.
Also note, Both products have proven longevity interms of shine, however, i think Zaino has proven its protective capabilities moreso than CG. This is because CG is a relatively new product whereas Zaino has been around for many years and thus has been put to many weathering and comparison tests. I have yet to see CG put up to 3rd party comparison tests.
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 16, 2003 | 04:25 PM
klez's Avatar
thank you very much and i decided on gettin CG after I've seen some pictures
i have one question though
since CG isn't wax or polish ,is there a slight chance that it might hurt the paint job
Old Aug 16, 2003 | 04:44 PM
RamboRami's Avatar
Hey no prob man, CG wont hurt your paint job if you follow the application directions. Basically its liquid glass, so you have to make sure you apply it with water and do not use too much pressure when spreading the product onto the body panels. Also, always use a microfiber cloth, you can buy them online or at your local auto retailer or large supermarket retailer (Meijers, Super KMart) 3 for $6 (TurtleWax brand)
Old Aug 16, 2003 | 09:33 PM
klez's Avatar
which CG should i get?
I usually detail the whole car once a month
should i get the CG wash or is it regular soap?
and what's that primer ,base coat ,and top coat .do i need those or will the CG quick just work fine
thanx
Old Aug 17, 2003 | 12:47 AM
RamboRami's Avatar
get the "Crystal Gaurd-Quick" bottle, its $50 but if you call them and tell them your from the G35driver forum then they might give you a 10% discount or something.....
You dont really need the CG Wash unless you have the PRO kit.
The PRO kit (primer, base, and top coat) only needs to be applied ONCE in your vehicle's lifetime, but when you wash the car, you should use CG Wash and once a year you have to use CG Quick to replenish the original coat.
That is option #1.
Option #2 (this is what i do and what was recommended to me by them):
Buy a bottle of CG Quick and 1 application will last you 4 months supposedly, but i do it every 2 months to be safe. It doesnt hurt because the car only gets shiny'er. The $50 bottle will last for 6-10 application, depending on how experienced you are with the product. "A little goes a long way" with CG.
I recommend going with option#2 as stated above, unless you are a professional detailer and work in an autoshop and have access to air toolz then go with the PRO kit.
Old Aug 17, 2003 | 12:58 PM
klez's Avatar
no I'm not a pro at detailing cars ,so I'll just get the CG quick
thanx
Old Aug 17, 2003 | 02:44 PM
wreck's Avatar
Running for his life!!
For the best shine, Klause is pretty damm good. For longivity get Zainos. I can't comment on CG cause I never used it.
G35C 6MT / AMG E55
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
st33zygill
Jul 29, 2015 10:05 PM
laksjd84
Jul 24, 2015 05:12 PM
