Zaino Directions?
Old Sep 1, 2003 | 12:52 AM
DaN_the_MaN's Avatar
Zaino Directions?
Ok Guys, I am getting my Zaino kit soon, so I just wanted to review the direction.
My car is brand new and I just washed it yesterday and I noticed that I have some swirl marks. I havent waxed it or anything.
So first off I am going to wash my car with Dawn. Then, without drying the Dawn wash, I am going to wash it with the Zaino show car wash. Dry it with a water blade and some micro fiber towels.
Then, I am going to clay the car with some lubricant and then wash the car again with the Zaino car wash soap. After drying, I am going to apply 2 coats of Z2 and 2 coats of Z5.
Sound good? Or do I need to add something?
Also, when claying, I spray some lubricant and buff the car using a circular motion? Then do I let it dry or continue claying the rest of the car and then wash it off with the Zaino car soap?
Thanks
Twilight Blue G35 Coupe 6M/T
Premium - Navi - Aero - Trunk Mat
Old Sep 1, 2003 | 02:49 AM
bkchang79's Avatar
Re: Zaino Directions?
1. Wash with Dawn
2. Clay bar, use a spray bottle with zaino wash and use it as a lubricant. Make sure to keep the are wet. Should feel smooth.
3. Wash with zaino wash
4. 2 coats of z-5 scratch remover with zfx (1 ounce is half of those little 2 ounce bottles)
5. Z-6 after the 2 coats of z-5
6. Use the polish (up to 4 coats or less, it's up to you)
7. Use z-6 between polish coats.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
Old Sep 1, 2003 | 03:46 AM
1. Should I wash with Dawn if I have no wax on my car?
2. Make sure to keep the car wet? or the bar wet? What
should fell smooth?
3. Ok.
4. 2 Coats as in polish the whole car once, and then polish it again starting from the same spot as the first coat? When I am applying the polish do I let it dry or wipe it off?
5. Ok.
6. Z-2 Polish?
7. Ok
Thanks.
Old Sep 1, 2003 | 11:07 AM
Meatshackle's Avatar
Deep Sea Moderator
1. yes, the dawn gets any grease oils, etc off the car so you can clay bar.
2. the caly bar directions tell you to use a spray bottle with some 16 oz of water and I think 1/2 capful of z7. spray a small area and run the clay bar across. you can feel whether or not the clay bar is getting stuck.
3. I waited for my first coat to dry then sprayed the car with z6, then applied another coat. You have to wait for it to dry or you'll just be moving it around. I used my finger to wipe about a 1" area to see if it was dry every once in a while.
6. Yes he is talking about z2 polish.
I applied two coats of z5 and ran out of time so I sprayed the car down with z6 and haven't applied anything else yet. The shine is still great and the car feels like ice. My swirl marks are gone so I'm going on to z2 next weekend.
I recently posted a thread called "Zaino'd the coupe" with some things I learned.
Russ
Black w/willow, 6MT, nav, & aero
Jax, FL
Zman's Avatar
I just did my car with Zaino for the first time yesterday. I did a Dawn wash, Z-2,then Z-6. Looks great and only spent about two hours.
I waited for about 60 days to be sure the paint was good and cured.
http://www.ppg.com/car_autocoat/enthusiast.htm
G35C 6MT CB Willow Aero Prem
Old Sep 1, 2003 | 01:24 PM
So it's not good to Zaino a new car?
Since the paint has not cured?
Im confused...I thought it was ok.
Old Sep 1, 2003 | 05:21 PM
Zman's Avatar
Sorry, I didn't want to confuse the issue. I just saw the TW Blue and figured that it just came off the boat so the paint may only have about 30 days of cure time. IMHO I feel that there is something to the 90 day wait regardless of the type of wax, chemical, etc...
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Rose M
Oct 12, 2015 10:00 AM
