clay or cleaner
Old May 10, 2006 | 03:54 PM
Gashed's Avatar
clay or cleaner
Before applying a protective coating is it better to clay or clean with say a McGuier's #1 paint cleaner?
Thanks for the tips.
Old May 10, 2006 | 07:07 PM
redlude97's Avatar
Both if you have time. Clay first, then paint cleaner. If you wanted to only do one, then I would opt for the clay. The clay picks up alot of surface contaminants etc, but the paint cleaner also removes light oxidation, makes the surface smoother since it has slight abrasives in it to smooth out the surface. Then apply your wax
Old May 10, 2006 | 07:14 PM
GLuXuRy's Avatar
^+1... do both
Old May 11, 2006 | 09:53 AM
Punchit's Avatar
Either one is good, both is better. Clay first then cleanser.
Old Jun 16, 2006 | 06:16 PM
Jeff92se's Avatar
Red Card Crew
I tried to use a cleaner wax with a machine polisher. Then I clayed the same area. the clay picked up crap that the machine polish did not. I highly recommend claying the car first. It will make the rest of the detailing steps alot easier.
junon
Jan 14, 2023 09:37 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Fire0nic3
Sep 1, 2015 12:12 PM
Frostbite91
Aug 12, 2015 05:16 PM
