25$ Cadence FX3001 Amp
Old Oct 19, 2009 | 12:10 AM
GWord256's Avatar
Back story:
It came with my truck. I don't want it. 'Nuff said.
I never tested it. I've no way of knowing if it works or not. Buyer Beware. I've no intention of shipping (except to the garbage). Your welcome to test it. I'll drive a reasonable distance to drop it off. Say to Hulen Mall from Glen Rose.
Here's the specs I got off of eBay.
Cadence Sound System
FX3001
Mono Block Power Amplifier
SPECIFICATIONS
4 Ohm Power RMS: 300 Watts x 1
4 Ohm Power Peak: 600 Watts x 1
2 Ohm Power RMS: 500 Watts x 1
2 Ohm Power Peak: 1000 Watts x 1
Frequency Response: 20Hz - 30KHz
S/N Ratio: >100dB
Minimum Harmonic Distortion: <0.05%
Damping Factor: >200 @ 100Hz
Channel Separation: >65dB
Dimensions (L x W x H): 12.7" x 11.0" x 2.75"
FEATURES:
High-Speed MosFET Power Supply
Studio-Grade Bipolar Output Stage Transistors
Fully Adjustable Low Pass Crossover: 40Hz - 200Hz
Fully Adjustable Bass EQ: +18dB @ 45Hz
Mute and Delay Soft Start System
Fully IC-Controlled Protection Circuitry
Gold-Plated RCA Outputs
High-Level OEM Head Unit Integration Harness
Would go great with some speakers
Attached Thumbnails 25$ Cadence FX3001 Amp-car-audio-2009-10-18-001.jpg   25$ Cadence FX3001 Amp-car-audio-2009-10-18-002.jpg   25$ Cadence FX3001 Amp-car-audio-2009-10-18-003.jpg   25$ Cadence FX3001 Amp-car-audio-2009-10-18-004.jpg
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
