My alignment saga continues....
Old Mar 25, 2008 | 12:30 PM
g35man04's Avatar
CLUB MODERATOR
Originally Posted by Moog
I don't know how you keep clogging up like that if you AFR is on point and not dumping fuel.
yeah the AFR is spot on...so I dont know..
Old Mar 25, 2008 | 12:43 PM
waijai's Avatar
i.love.gold
Take off a cat and look inside.
Old Mar 25, 2008 | 12:45 PM
g35man04's Avatar
CLUB MODERATOR
yeah im going too..MY SES light came on as soon as it happened....
Old Mar 25, 2008 | 12:58 PM
waijai's Avatar
i.love.gold
You should check the code as well. Go to Autozone and have them check it.
waijai's Avatar
i.love.gold
sorry for getting off topic Beerviper
Old Mar 25, 2008 | 01:23 PM
BeerViper's Avatar
Originally Posted by g35man04
Also if I were you I would by the rear camber kit from them...just dont get the bolts...get the whole thing..
I already have Stillen camber bars but the more the camber is adjusted, the worse the toe-in gets ... hence the need for only the toe bolts.
Old Mar 25, 2008 | 01:30 PM
BeerViper's Avatar
Rockauto.com has an alignment kit for $22.79 that looks like the SPC toe bolts.
Yeah that looks to be essentially the same thing, thanks for that website, never heard of it before but it seems like a great resource!
Old Mar 25, 2008 | 01:38 PM
BeerViper's Avatar
Rear camber really doesn't wear out tires that badly, just make sure your toe is correct and you're good to go.
Well I guess that depends on what you consider "wear out tires that badly"... This was with rear camber at about -2.25 with toe very close to spec...
If the toe is off, it should shred the whole tire whereas negative camber just rides the insides of the tire...
Old Mar 25, 2008 | 02:14 PM
g35man04's Avatar
CLUB MODERATOR
yes your correct which is why I made the comment about the camber and toe arms...i havent any isues in the rear of my car since I installed the SPC camber arms and toe bolts.
Old Mar 25, 2008 | 03:21 PM
Mad A's Avatar
If you'd like to grab the Cipher to do some logging to try to figure out what is going on just let me know. That's what it's here for! Also, you can scan the code and see what it is and clear it as well.
Back on topic, I'm looking at getting the BC coilovers, so I would need camber adjustment kits as well, let me know what you go with Jon and how it turns out.
Old Mar 25, 2008 | 03:39 PM
g35man04's Avatar
CLUB MODERATOR
thanks MAD A..I have this http://www.autoxray.com/whats_new_detail.php?id=41
Old Mar 26, 2008 | 02:08 PM
BeerViper's Avatar
I went ahead and ordered the toe bolts from Eddie at THMotorsports, he gave me a good price. I called over to Rock Auto and their price is $22.79 but that's only for 1 toe bolt so Eddie's shipped price is actually better.
Hopefully this will take care of the rear alignment and I won't have to replace that knuckle on the drivers side.
I still need to look into that TopSpeed front camber arm to see if it will be enough to pull a degree or so of positive camber...
Old Mar 28, 2008 | 09:54 AM
waijai's Avatar
i.love.gold
man they're making a killing on those bolts...i bet it costs pennies to make
Old Mar 28, 2008 | 10:16 AM
TwoK4drSi's Avatar
Damn, I could be slanging toe bolts instead of crack and make a fortune! At least toe bolts aren't illegal
Old Mar 28, 2008 | 11:00 AM
  #30
BeerViper's Avatar
Yeah it's highway robbery (percentage-wise at least). Fortunately they're only marking up a $0.49 item 10000%, just imagine if they did the same to the camber arms
