i need camber kit help!
Old Jan 30, 2010 | 01:35 PM
LordFappington's Avatar
its on their website.
3301 wood street ste 100
garland,tx 75041
and actually sorry looks like they are closed today.
My06BlkG35's Avatar
nvm i got it i just need to talk to jason i think thats his name
Old Feb 3, 2010 | 09:02 AM
BeerViper's Avatar
IMO all you need is a good alignment, my front camber is hella negative and I get zero tire wear...
Old Feb 3, 2010 | 12:18 PM
My06BlkG35's Avatar
well thanks for the help everyone i got camber kit already now i just have to put it on and get it fix thanks for the help
Old Feb 7, 2010 | 11:02 AM
GWord256's Avatar
I'm chiming in a little late, but can't you put shims in behind the wheel hubs? My SPL arms came with a couple shims for dropped cars to get the camber back to daily driver values. Couldn't these same shims be used without the adjustable camber arms? I never installed them because I want the -2.5 for tracking purposes so I'd be willing to share.
Now thinking about it behind the wheel hub seems odd, maybe they go somewhere else to achieve the same purpose. I don't have the instructions in front of me.
I think i have 2 pairs of shims at +1.0 and +2.0. They are piled up with all my other car parts somewhere.
Old Feb 7, 2010 | 11:07 AM
GWord256's Avatar
Hush You! Extreme cornering evens out that inside tire wear quite remarkably. At -2.5 my outsides always wear out first. But the only time the car is casually driven is to/from meets or to/from the track.
Old Feb 7, 2010 | 12:36 PM
My06BlkG35's Avatar
well i got im still not happy with my sh^t i got the camber kit on and got it check and is still eating tires before was -2.3 now fronts are -1.6 both sides and the before -2.4 now rear are -2.7 and thats hella camber in the back but i dont mind cuz is flush w.e that word is lol so..anyone have idea for the front cuz i hate eatin tires in the front???? running 255 in the back and 235 or 225 in the front...
Old Feb 15, 2010 | 11:14 AM
BeerViper's Avatar
Dallas Frame & Alignment FTW
Old Feb 15, 2010 | 12:35 PM
My06BlkG35's Avatar
whats that post to me and where is that place at and how much?
Old Feb 15, 2010 | 12:47 PM
User 92024's Avatar
http://www.dallasframealignment.com/
2514 Fabens Road
Dallas, TX 75229
(972) 241-2361
Price is dependent on your car and the work needed. I've taken all 5 of my previous cars to them and the price ranged between $65-$85 depending on the complexity and the issue. WELL WORTH THE COST! These guys are the best, period. They will be doing my alignment after my Camber/Toe kit install, even though I have a Firestone lifetime alignment. The only reason i got the Firestone lifetime alignment was because i needed a decent place that was open on the weekend in case i needed an alignment done on a weekend...and it has come in handy more than a few times!
Old Feb 15, 2010 | 05:53 PM
BeerViper's Avatar
Yes that message was for you, what I was trying to tell you BEFORE you went and spent the money on a camber kit is to get an alignment from a shop that knows our cars...
I have seriously negative camber on my front wheels with my TEIN Flex coilovers and with the alignment I got from Dallas F&A I have not had any uneven tire wear under daily driving conditions (neither front nor rear). HOWEVER, the tires may wear evenly at a slightly faster rate than if I had in-spec camber without the drop due to the way the alignment is done (slight toe-in). The guys at Dallas F&A know their stuff and work on G's and Z's all the time. You may get lucky and find a guy at your local Firestone or Goodyear dealer that knows how to properly align a lowered G/Z but I can assure you that it is hit or miss. With Dallas F&A you will not be disappointed and they will stand behind their work.
Old Feb 15, 2010 | 06:36 PM
My06BlkG35's Avatar
thank you man alot ill try it out when i get my rear camber kit in wit the toe bolts i need to find a good deal jotech charges me 280 for rear wit toe bolts so..idk about that
Old Feb 15, 2010 | 11:40 PM
BeerViper's Avatar
I did the rear toe bolts on my G just following a DIY thread here on driver. With the right dremel bit it took me as long to jack up the car as it did to install the toe bolts.
I already had adjustable rear camber arms but those shouldn't be too bad to install either.
Oh yeah I have an extra set of SPC Toe Bolts if you need a pair, don't remember what I paid but you can have them for cheap if you want.
Old Feb 16, 2010 | 01:22 AM
My06BlkG35's Avatar
how much for the toe bolt ?
Old Feb 16, 2010 | 09:50 AM
  #30
BeerViper's Avatar
$20 for 1 pair of toe bolts
