I know and I was hoping that motordyne resonator would kill some of the drone. I can't imagine it with just the straight pipe
Quote:
probably something to do with the strut... that rear wheel would be getting only a little pressure at that point.Originally Posted by syshs
I get a pop from the rear passenger side ONLY when I turn right into a uphill ramp, doesnt matter how small or big the ramp is. Its kinda annoying.
CLUB MODERATOR
Quote:
haha the MOtordyne ART Pipes wont quiet it down bro!! Originally Posted by almost3flips
I'm hoping with the art pipes it will quiet it down some. Hope those big *** heimholtz resonators do the job
Topspeed exhaust is known for being a very loud exhaust. its pretty much just straight through exhaust. The resonator will help alittle but you should look into the full CAT piece if you want to quiet it downGonna leave them white? Or did someone already change that? I think they'd look hot on your car with them being white
CLUB MODERATOR
Quote:
I want to have like a shop grand opening aka G tuning party.
do I get to tune for free! Originally Posted by sexyrob
ok just messaged Steve to see what kind of pricing he can do for us. I want to have like a shop grand opening aka G tuning party.
Quote:
Thanks Doc, my car now feels and sounds solid again..
your welcome Sir!!! Originally Posted by twalls
Front coil installed, and Dr. Frankenstein (aka CBlack, aka G35man04) also found the freaking "creak and pop" that was coming from my driver side rear.. Apparently, when I went true coil setup, the spring bucket wasn't tightened down.. Since there was no spring back there, it was just back there loose.. No, it wasn't R1 either.. Thanks Doc, my car now feels and sounds solid again..
I will edit my profile now!Quote:
sounds so much better now!Originally Posted by JaE35
lol good stuff, chris is fixin every damn. thing
Quote:
Phi he actually wants to drive his car now! I started him off again!Originally Posted by almost3flips
Glad your car is getting closer to 100% again tony. That spring bucket thing is ridiculous lol
Quote:
it sounds better now! so get your *** to some meets!Originally Posted by twalls
Man that pop was driving me insane, another reason I wasn't driving my car.. 04, w/ barely 53k.. Car was sounding raggedy man..
Quote:
That's what the "up" arrow on the volume button is for
haha Im with you!!! turn the Volume Up louder!! trying to explain this to Jared (Trix) right now.....once your start modding get used to it!Originally Posted by JBF
I hear pops, creaks, rattles, scrapes, rubs...all the time.That's what the "up" arrow on the volume button is for
Quote:
That'd be a good "sound off" comparison, just at idle, don't even have to hit it.. Just to see who idles louder.
my car shall be louder at idle since my idle is turned up!!!! If his is louder....you know what I do....I GO LOUDER!!!! if it takes me running open headers....DONE!Originally Posted by twalls
Dude.. Seriously, I think you've got Chris beat for loudest Exhaust in DFW bro.. I'm dead serious, I was in the BACK of my house, and I heard you around the corner easy, and it was still vibrating in my chest.. That'd be a good "sound off" comparison, just at idle, don't even have to hit it.. Just to see who idles louder.
CLUB MODERATOR
Quote:
hes thinking of testing them out behind his wheels in white first before he questions changing them!Originally Posted by BlueBOB
faiz23
close
- Join DateNov 2006
- LocationYour mom's bed
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:291 Times in 218 Posts
I plan to run down to infiniti to get service records and then work on the moonroof and clean it up along with adding grease and lube to make it smooth. The moonroof is slightly dragging towards the end and some moly grease will help the motor from not working as hard. I swapped out some of the clutch fluid and will be doing the rest over time and have it swapped out to new and bleed the line. Plan to add some wd-40 to the clutch pedal to make sure it is nice and smooth. Changing the fluid helped with pedal return and smooth shifts. I am able to have a better feel of when engagement is and pedal return quicker after engagement point. Had some better tires thrown on the car since my old one were at 3/32 and out of balance. Got these of CG so they only had like 6/32 but enough to get me by till i am ready for full suspension swap and tires cost like nothing.
https://g35driver.com/forums/g35-sed...any-fixes.html
Edit: Haven't had any issues with clutch pedal sticking upon return except once from when i picked up the car from dealer on the first day. I have replaced clutch fluid and plan to lube clutch pedal as preventative maintenance. If the problem returns then i will change out the slave cylinder and then master cylinder. As of now the clutch, clutch pedal and assembly are working A - OK
Haha no way am I ever going back to any sort of cat. Sorry environment but you're fcked anyway Originally Posted by g35man04
Quote:
Trust me man, I don't want the loudest exhaust title! I think yours is louder than mine because when we left one of the meets, I was in the parking lot still putting GPS shiz in and you were turning out of the parking lot heading down the street and turning at the light, and it was still loud as hell haOriginally Posted by g35man04
XiN
Supersonic... Hypertonic
close
- Join DateFeb 2010
- LocationHouston
iTrader Feedback Score(17)
- My RideItasha Coupe
Liked:430 Times in 278 Posts
Bob... Chris right. Going to see what they look like white behind the wheel first before I think of changing them.
