[DFW] What have you done to your G Today?
Old Jun 14, 2011 | 01:35 PM
  #6691
LordFappington's Avatar
Nice now you just need bags to set up that suspension for track use.
Old Jun 14, 2011 | 01:39 PM
  #6692
twalls's Avatar
CLUB MODERATOR
I looked at the motordyne sways.. I don't think they're 3 way adjustable are they? That's why I went w/ stillen..
Old Jun 14, 2011 | 01:40 PM
  #6693
g35man04's Avatar
CLUB MODERATOR
lol bags.......Funny guy jack! I have never installed energy suspension bushings so thats a new one.....hope that you dont have any noises with the energy suspension ones. I went with a solid setup for the compression rods since thats where almost all of your movement in your suspension will be at.....having solid will limit that movement making handling alot more precise! if you ordered the compression rod bushings did you order any of the other Lower Control Arm bushings??? Shock tower mount or inner control arm bushing deemo???
Im asking because you have to remove both of those components to swap them out.
Old Jun 14, 2011 | 01:42 PM
  #6694
g35man04's Avatar
CLUB MODERATOR
yes they are 3 way adjustable
Old Jun 14, 2011 | 01:49 PM
  #6695
Deemo's Avatar
yeah they are 3 way adjustable. . I was going to order stillen, but law@strafe stopped responding to my pms. .I didn't hear from him for 24 hrs. . So i hit up charles at b2 and he only stocks motordyne or hotchkis.
Chris, supposedly you don't have to press in these bushings like the other ones. .not sure if that makes sense, or if thats even true. I was going to go with spl solid ones but I found a member that had 20 energy sus. bushings left over. brand new in the box for $60 shipped for a pair.
No I didn't order anything else chris. .But if you honestly think it be a good idea. . I will go ahead and order them. I can just have stephen knock them out while he's under there. I know stephen has changed my translink bushing on the lower control arm...
Old Jun 14, 2011 | 01:56 PM
  #6696
gmotion04's Avatar
ordered some front stoptech rotors and stainless steel lines from b2auto so i can finally put my hawk pads on that have been hibernating for 8 months
Old Jun 14, 2011 | 01:58 PM
  #6697
g35man04's Avatar
CLUB MODERATOR
all bushings have to be pressed in...even the compression rods. You have to press out the whole compression bushing that exist...if nothing is pressed back in then you dont have compression bushings anymore to absorb your suspension.
with that being said I would recommend doing all the fronts at one time and having them all knocked out. you just need to order the shock tower mounts and Inner Lower Control arm from whiteline....its easier honestly with everything is removed.
I will be doing my SPL compression bushings and shock tower bushings as soon as I can get feeling better and I am able to do it.
Old Jun 14, 2011 | 02:03 PM
  #6698
g35man04's Avatar
CLUB MODERATOR
the ones that I have seen may not need to be pressed but it looks like you just stick a piece of metal pipe in between and then slide in the urethane pieces and just press them down.......not sure I like the sound and look of that.
Old Jun 14, 2011 | 02:04 PM
  #6699
Deemo's Avatar
Okay, I will go ahead and order the shock tower mounts and inner control arm bushings.
Old Jun 14, 2011 | 02:07 PM
  #6700
Deemo's Avatar
I just was reading the thread and the guy said that these not need to be pressed in or something like that.
I'll get the exact quote and show you in a second.
EDIT:
Here's what he said. . .
Originally Posted by vinco
PM's replied.
These are cheaper than Whiteline, plus you don't have to press the new ones into the arms. They are heck of a lot better than OEM, but a little more expensive. They are just over half the cost of the Nismo hard rubber bushings, and once again, you don't have to have a press to reinstall the new bushings in the arms. IMO, this is the best product available for this particular application, and that's why I bought a bunch of them. You cannot buy just the compression rod bushings from the factory except in bulk. I'm sure that the other "regular" parts dealers that offer them did just exactly the same thing as I did and made a bulk order from the factory. No dealers had them either when I ordered them. The factory was kind enough, though, to fill their dealers bulk orders before they filled mine :-) I ordered these things 2 and a half months ago, and they just finally delivered them to me on Tuesday. I'm not a parts dealer, and this is the only product I have to offer.
Old Jun 14, 2011 | 02:10 PM
  #6701
g35man04's Avatar
CLUB MODERATOR
order them from kyle. he is also a vendor on here.....
http://www.importpartspro.com/rebu3.html
you got the quotes and the order from this guy.
[url]https://g35driver.com/forums/steering-suspension/377811-energy-suspension-compression-rod-bushings.html[/url
Old Jun 14, 2011 | 02:11 PM
  #6702
Deemo's Avatar
yeah. read my post above.
Old Jun 14, 2011 | 02:15 PM
  #6703
Deemo's Avatar
so i need this
http://www.importpartspro.com/w52991g35.html
and this
http://www.importpartspro.com/w52992g35.html
Old Jun 14, 2011 | 02:17 PM
  #6704
g35man04's Avatar
CLUB MODERATOR
I know where you got it from. I dont like the sound of not having to press in bushings that withstand all of the force of your suspension and handling.
you can also pm kyle right here.
https://g35driver.com/forums/suspens...r-pricing.html
Old Jun 14, 2011 | 02:21 PM
  #6705
Deemo's Avatar
lol well I wish i talked to you first. . maybe the guy just says that, but they do actually have to be pushed in.
i'll send kyle a pm shortly
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
