[DFW] What have you done to your G Today?
Old Jun 14, 2011 | 03:20 PM
  #6721
gmotion04's Avatar
damn good thing the stillens came on my car and i didnt pay for them but hollow wtf!
  #6722
r1forever80's Avatar
I paid 200 for f & r hotckis used though and they are v2s
Old Jun 14, 2011 | 03:23 PM
  #6723
BlueBOB's Avatar
I guess depends on how hollow it is... still stupid.... not enough of a weight savings to be worth while... other areas are much more effective... like the entire body haha
Old Jun 14, 2011 | 03:25 PM
  #6724
twalls's Avatar
CLUB MODERATOR
eh.. paid 180 used.. and I asked about the motordyne CBlack and you told me to go w/ the Stillen
Old Jun 14, 2011 | 03:26 PM
  #6725
It also depends on the metal bein used. If some were heat treated then they could b hollow, smaller, and still stonger than others that werent
Old Jun 14, 2011 | 03:28 PM
  #6726
Deemo's Avatar
wow. . .Well I couldn't find any sways used, and I wanted to order them to get them installed along with the endlinks, so i went ahead and ordered new. Motordyne sways are 320 new from b2. Stillens are about 290-300 i think, and hotchkis are like 350-400 i believe.
Old Jun 14, 2011 | 03:37 PM
  #6727
Deemo I could of gotton u some hotckics cheaper than those motordyne. My bda
Old Jun 14, 2011 | 03:39 PM
  #6728
Deemo's Avatar
dammmmmittttt mayne.
Old Jun 14, 2011 | 03:54 PM
  #6729
jran76's Avatar
There is nothing wrong with hollow. They are lighter and it is fully possible that they are stronger.... Many major brands are hollow (Hotchkis, Nismo, Cusco, etc.).
From Hotchkis:
Now, many misconceptions are floating around about the hollow bar designs. One major one is: that a solid bar is stiffer than a hollow one. This is only partially correct. If a solid bar and a hollow one of the same diameter are compared, then the solid bar is stiffer than the hollow version. By increasing the outer diameter of the hollow bar, and fine-tuning the wall thickness, you can yield the same performance while reducing weight. How many racing designers try to cut every ounce out of the chassis? They all do! Reducing weight acts like adding horsepower.
Another expressed concern is the durability of the part when using a hollow bar. Under the same loading, a properly designed hollow bar will see virtually the same stress levels that a solid bar does, yet provide the equivalent handling performance or improve upon it.
Link: http://www.hotchkis.net/_uploaded_fi...ons162file.pdf
Whiteline basically disagrees with the above saying that hollow bars are more expensive, harder to make, and don't save much weight.
Link: http://www.whiteline.com.au/docs/bul...%20Swaybar.pdf
Basically, take your pick.... But, don't be afraid of the hollow bars....
Old Jun 14, 2011 | 03:57 PM
  #6730
Thanks josh. Some people rather throw out their opinion rather than do research. I'm sure most of the companies have done their r&d
Old Jun 14, 2011 | 03:58 PM
  #6731
BlueBOB's Avatar
yea, I actually put my physics mind to work which is why I said I guess it depends on how hollow it is... the shape itself is very strong and can hold a lot, but it all depends on design... and in most real racing, weight is regulated anyway, so they don't necessarily cut every single ounce possible... in the end, personal preference and budget will be the ultimate factors
Old Jun 14, 2011 | 03:59 PM
  #6732
BlueBOB's Avatar
i disagree with the end of this statement for many reasons... some companies just make **** cause they know people will buy them... you KNOW it's true
Old Jun 14, 2011 | 04:09 PM
  #6733
I was mostly reffering to the bigger companies. There are a lot of companies that are copying others designs using less quality products. Yes I'm sure there is stuff bein made and bought for no reason. Just go to traders village and u will see a ton of examples
Old Jun 14, 2011 | 04:39 PM
  #6734
jran76's Avatar
Yeah, I think the moral of the story is buy something reputable, and you should be OK with something like sways. Stillen, Whiteline, Hotchkis, Nismo, Cusco, Motordyne, etc. should all be OK. They are all pretty reputable engineering companies. Go with what you like, or what you can get a deal on. I know some offer more adjustability, but that is about it as far as benefits of certain brands (and for most that probably doesn't matter for most people). Hollow vs. solid does not matter. I would personally go hollow for the minimal weight savings, and that is what I had (Nismo, and I know they worked...).
Old Jun 14, 2011 | 05:41 PM
  #6735
LordFappington's Avatar
I dont use sway bars.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
